Discuz! System Error
MISCONF Redis is configured to save RDB snapshots, but it's currently unable to persist to disk. Commands that may modify the data set are disabled, because this instance is configured to report errors during writes if RDB snapshotting fails (stop-writes-on-bgsave-error option). Please check the Redis logs for details about the RDB error.
PHP Debug
No.FileLineCode
1forum.php57discuz_application->init()
2source/class/discuz/discuz_application.php70discuz_application->_init_cron()
3source/class/discuz/discuz_application.php584discuz_cron::run()
4source/class/discuz/discuz_cron.php27discuz_process::islocked()
5source/class/discuz/discuz_process.php18discuz_process::_find()
6source/class/discuz/discuz_process.php46discuz_process::_cmd()
7source/class/discuz/discuz_process.php65discuz_process::_process_cmd_memory()
8source/class/discuz/discuz_process.php75memory()
9source/function/function_core.php1722discuz_memory->add()
10source/class/discuz/discuz_memory.php99memory_driver_redis->add()
11source/class/memory/memory_driver_redis.php93Redis->set()
12source/class/memory/memory_driver_redis.php93break()
bbs.audioapp.cn 已经将此出错信息详细记录, 由此给您带来的访问不便我们深感歉意.
