推挽式放大设计,3级反向达林顿电路,消除失真
' S! q x. B0 X% H
* C5 R* d4 J( Q# K 所有输出级分离电路
3 H! I0 j) O; t- T7 x
9 n/ Z' u; K7 K2 j, Y | 巨型环形变压器' _- i- ?% |% H' p5 [3 ~; e! E
3 f% ^1 p X; _2 u5 G* H, r 2个定制的大型22,000 µF 电容器,提供有效电源
+ o0 i) A* ?: }% p K; O @9 V3 Q3 ?- `) l! p
每个声道定制的音频调谐参考电容
/ Z" K# X+ y2 c: u8 u# n I
+ \: s* R+ o" U& B( ]$ p& d 定制设计的大型功率晶体管,驱动高电流
! S+ ~$ ^7 n! A+ n- ] F3 ]) q; e7 n8 c' ]+ Q' A. w3 |0 e2 W
可实现完美接地电位的厚铜电路板0 ^* D& h- t. U& r
4 {8 h0 O; Q% z1 x 带厚铜箔(70µm)的高电流、低阻抗电路板
! i5 b" a) d/ E0 u' }6 r5 f6 h; F5 @$ H" N) R
平整、高硬度的抗共振机箱
. x! D3 A! a- R2 v) T
3 g( W, O- D6 }% v0 I" f 镀金XLR平衡输入
6 S; G0 Y, g4 v( O" b" a6 I1 Y3 r0 S7 e" T# w6 a7 [
加固实心的黄铜RCA输入$ ^$ o* p# {& T# j
! K. f% o- Z2 J9 _# X. ^3 ^+ y 镀金的、彩色编码的、可兼容香蕉式插头的透明扬声器接线柱
$ j/ m6 [, }" D& ^9 \0 d/ E4 L+ b' Q& z
多区域功能(多达3区)※1+ j; u- d$ w; i) y# B: ~. m
/ e9 L# i- T# S9 i+ T3 h& @; u 双功放功能※1
" L% s) @8 F: A% e; S0 y5 E# q. [5 t5 I g6 C5 }% m6 p/ p
12V触发器输入
. e% A) p* ?0 m9 d8 O/ |
% u9 P- s/ t2 o+ `: E 自动关机功能! R% _7 {+ K; t7 B# u/ V$ N
2 ~) W4 ?$ }9 ~3 `3 K+ U
铝制面板
+ ?" M# [+ E7 N1 n) G& x+ j9 w+ U7 j# g: T; ~3 H
THX Ultra2认证
2 E! Y: L# W) Y, ]) O% x+ ?2 h2 ?+ }7 X/ Z( ]/ E
如果一套家庭影院获得了THX认证,那就意味着它将还原出和录音室一样的电影效果。THX ULTRA2认证这个家庭影院效果终极的标志,需要功率放大器必须在大房间的多声道播放中有着高品质和高电流输出的表现。THX判断功率放大器是否合乎标准的条件就是持续功率输出的测量,失真率,和抗热特性。) |; I( M0 d2 ~$ x( |
- G/ [' v* U" Y+ _ C5 v) |
JBL Synthesis S820 200W*2 声道32公斤, q% K( M9 y: O1 V: p; j# x+ g! M
. k' e7 V! G; G2 ^, C) I
The S820 is a 2 x 200 watt power amplifier that has been designed and crafted to provide the user with a high level of sonic performance. Special attention has been paid to minimize the number of components in the audio signal path, resulting in extremely low distortion, excellent transient response and wide dynamic range.
- @ g. r! d0 F" U9 m5 f1 v5 J, J
+ U! v c% @* l* L3 f2 h Synthesis® products set new benchmarks in audio technology, and, when used as part of a complete JBL Synthesis system, will bring the ambience and acoustics of some of the world’s greatest concert halls and theaters into your home. The JBL Synthesis S820 power amplifier features the following:: j ~8 W8 W& z0 z; Q$ y5 J1 {, Y9 ]- Y, }
* O0 y! Q" X: r# A6 f/ Q3 Z% @ Multichannel Operation1 R) h* o' r% ]2 M) C! P, j
# ]% s: p5 v4 [. n+ |
High Power Capability
$ z- v9 W9 R- {* x
4 b3 @) `. q8 ? Auto Turn-On and Power-Sequencing Circuitry9 ~2 l& U# `2 u
& W" B- I( C8 I( J B o Quiet Fan Cooling) K: K% I6 o0 l' s
+ o3 c; V$ r q. R1 K2 _
Comprehensive and Isolated Circuit Protection) N3 y |) N" z4 E/ V& e
, X4 r5 n3 _; \. t: [6 B) j Balanced and Single-Ended Inputs
# [2 ]1 W) |4 A7 n$ T1 y, }
0 c* U3 E7 P2 |, G, \/ h1 M OPPO 105D 顶级蓝光播放机( V5 [" H0 G, x2 r1 N8 J+ s
# `; p1 m# m. Q7 a9 g) C 性能强劲4K画质名不虚传音乐效果好( X. x; `" o3 a% F4 k
+ {) U4 t! B+ |* I2 a; I$ V
BDP-105D在BDP-105的人性化设计和丰富功能基础之上,对视频和音频部分进行升级;视频部分采用DARBEE影像增强处理器Altera Cyclone IV和Silicon Image视频处理器SiI9616,音频部分升级异步USB DAC处理芯片,支持DSD64和DSD128源码输入,带来震撼的视听享受。
5 |1 c. O0 P6 w% d! x6 [$ M) ?
2 L" @* ] ~! L- M" j: i' F 105D得益于DARBEE影像增强处理器,视频部分和105还是有很大的提升,在视频设置页面增加了darbee模式,分为高清,游戏,全开,同时增加了细节增强,边缘增强,视频平滑化选项,采用了与和0ppo83的视频设置模式,基于这些设置,105D的视频比105更加锐利,画面更加清晰,景深好,更有立体感,一句话简单概括,105D画面更加通透,锐利,105画面相对就好像蒙上一层纱的感觉,个人感觉,105D如果在价格合理的情况下,105的用户,升级105D还是很值得的,毕竟画面提升明显。! b. S' D/ X; p, A! C A4 o
% T/ Z+ l+ i% p' g" Q
105D输出的低频比105更有力和纯净,而往下的潜入性更广,同时有一点非常明显的就是,高音亮丽有所提升,让环绕效果同定位都明显了很多,贴身感又近了一步。
i1 K9 u4 o7 m
6 [6 X7 f' ]7 L7 I' z, q% D7 M) | EPSON CH-LS10000 爱普生顶级私人影院投影机
* S% V# K+ t' C9 H+ O
0 {8 i/ w: T$ j. e$ I 爱普生是世界领先的创新企业,主要产品包括喷墨打印机和打印系统,3LCD投影机、工业机器人、智能眼镜和传感系统。爱普生基于省、小、精技术,跨越商务、家庭、商业和工业市场,致力于为全世界的顾客提供超越他们期待、开阔他们视野的产品与解决方案。& r$ S! |; t( N" ~" H# e8 m
4 g6 f/ P- H1 H l% F
位于日本的精工爱普生公司是爱普生集团的核心企业。爱普生集团在全球设有94家公司,员工总数逾72,000人。爱普生为全球环境及其所在地区的社区发展不断做出贡献,并以此为荣。& U* X- T G" P: O+ }
. U: u! s c5 O/ R e7 K2 }* E& W
前所未有的爱普生顶级私人影院投影机. }5 {9 P9 `) U
7 m9 q" p* I+ i. [6 M
激光光源与3LCD 反射式液晶面板的完美结合,令CH-LS10000可实现极致的黑位表现及逼真色彩;4K增强技术使电影摄制者最初捕捉到的所有细微之处全部得到完美清晰的呈现。
) B- M4 P0 P9 r/ ~* K! r9 }! x
+ |! k- o6 `% J 这已不仅是投影,更是爱普生家庭影院的终极艺术之作!
8 B9 a6 P/ A5 Q& l9 D% y: G0 D8 ?- ~' V+ v1 h
CH-LS10000是爱普生首款采用激光光源的投影机。激光具有广色域、3万小时*1超长使用寿命、超高对比度等诸多优势。此外,激光还能实现迅速开关机,为您节省等待预热和冷却的漫长时间。# i+ b' C- }3 e! Z9 K
( U2 P" V, V! i2 T, E 双激光光源
9 I2 u5 @$ N2 S3 x: m+ V9 [. l2 r0 L: M1 E1 M
双蓝光激光二极管光源,一路发射红光(R)和绿光(G),另一路发射蓝光(B)。激光光源实现了完美画质及省心耐用的革命性投影。3 D/ }3 f9 x9 S; W( A, V
. ]/ C8 R& R5 L- |8 D 省心耐用
$ [; a1 w% d; B* O" K% d/ U ]1 h* W) I& l
3万小时*1超长使用寿命
K" O# m$ o! k7 h* o; ^& T3 z1 S5 l9 O D4 l
ECO模式下实现30,000小时*1超长使用寿命,几乎无需担心后续的耗材维护等。
7 p5 ~ i4 S$ Y1 W) \; Z6 O
4 D5 z Y0 [4 b 超高对比度-极致黑位表现
- n3 n9 W7 W* ]' d- v
6 T- K( u4 O% I: m" o7 t 体验难以置信、前所未有的极致黑位表现-全黑场景时,达到0流明!/ j# @- {6 n0 w3 C3 K
! _2 g! B& N' j7 }' A7 k1 s0 @
精彩画质& N- V* e! U: V: E& o: h
1 }" h$ }, @: G& H- D0 z 更广的色域! ]0 f2 ^% p h, r
- g- O; G( b* `" g$ h; L! x
充分享受明亮鲜艳的色彩,即使在最亮的色彩模式下,也能实现100% sRGB色域,甚至能实现数字电影标准的DCI色域。6 n0 v V2 A% x4 B4 a
$ o" c" A9 g0 q$ Q 3LCD 反射式液晶面板
8 k! l d; u F. K3 z' z+ U8 e3 [7 b; L2 X6 \/ ?# E
反射式液晶面板光利用效率高、体积小、开口率高,能呈现更平滑的图像和更充分的色彩。
0 L8 C3 _8 G1 M2 q3 i
3 i& r7 m5 p; ^( M/ B5 j 4K增强技术*26 G+ ~. t6 ~0 S( d/ j: T9 i/ {& k' Y1 p
& I+ ]4 X6 D+ k" c1 c* b
爱普生4K增强技术能令普通及高清片源内容看起来更加栩栩如生, 每个细节均能得到难以置信的还原。4 \; e. Y, K% a7 |* w0 N
3 m( D) k# ]9 g; i0 V$ T THX® 认证+ @! ?& n& ^# C9 ]* t
$ s5 f$ d- w1 G6 U c+ g5 Y- B 确保精确的画质和杰出的性能。) n7 M8 \+ N0 m) e
* ~2 I' c& ]% Y0 j% l! S& c ISF® 校准" G, W& W7 N2 R7 @+ R4 u0 B2 V
' i* z. \# `) R; s5 R. w0 h3 { 使用ISF校准工具实现完美投影效果。; f) t/ I& d, N/ l" _! y
+ Y0 F) h; B! w
4 t5 [* d6 C9 T7 i8 `
+ a* v3 a$ w3 Q* `5 C7 T
EPSON CH-LS10000- [) ?. ~8 s; z! J" S
0 t& O) [& w, t4 y+ t: |# {. \# n8 z& u* G
Screen Research 184英寸16:9 画框透声白幕6 ] Z" {$ F! _+ g. E% l9 F; l
7 B, K% n( z3 d8 S' x& @ 法国Screen Research公司是一家专业的顶级银幕制造厂,专门研发、制造家庭剧院、商用及专业剧院使用的各种银幕。凭藉着优异的技术及品质享誉欧美。总部设于法国的南特地区,其产品销售至全世界超过37个先进国家,广受顶级用家、专业人士及各方媒体好评,并连续获法国戛纳(康城)电影节的官方银幕提供商,欧洲DTS实验室的御用幕布,成为众所瞩目的世界一流高级银幕品牌。
2 J/ }/ v* [! F$ \, H* n9 `0 B; ? D
Screen Research的主力产品—透声幕,乃采用独家专利的编织技术制成,除了使全频段的声音可以在不失真的状况下,顺畅的通过银幕外,还可以避免和投影机的画素发生干扰而产生“错网纹”(Moire Pattern)。+ Z) e: w& x5 M% i) P7 p
' }! R: p7 j' w& Y1 |& M" O 法国Screen Research 承诺给您对声画没有妥协的最佳投射屏幕: 家庭影院真正成为令人难忘的体验。
, s2 [( T1 S6 P3 `& w$ v2 C' P/ e( Q ~ q
ClearPixTM , 从屏幕研究开始, 她是世界上唯一结合完美声音和图象质量的透声屏幕。经由THX 和ISF 认证, ClearPixTM 确保了最佳的声音和画面的表现。7 M* D& G" z. E# ~2 E
4 W; T1 D6 g6 Q: G- P 使用ClearPixTM 观赏电影是最佳的方式。因为音箱最理想的摆放位置是在屏幕之后, 图象和声音能完美的融合在一起。2 C) D/ K) z, B3 t' y* l
6 m6 y( P1 T! r. g; q) d. V5 N8 x
新一代数码投影机的最佳伴侣。杜绝普通打洞式透声幕造成的波纹(Moiré )现象。极佳的透声效果,完全不需要EQ 去调整!5 w& c, R; e0 a. d9 X0 j. a. V
. b7 U' f5 N8 f% w
JBL 7.2.4杜比全景声4K 3D家庭影院配置方案列表
) j0 d' M' J: Q: i; u n6 i8 [2 L3 Y$ U' e# I& \3 b
产品名称型号及规格单位数量1 Q8 A% z' B( v
2 I9 M" D& L4 t8 q* i. I6 \
JBL落地音箱ARRAY 1400 1对4 P% v8 I. Q$ d2 E
. v" K% w" ^4 M' }8 M2 A! H8 ?
JBL中置音箱ARRAY 880 1只
9 ^# ~% E' }% s
" R/ \% G$ |! [) X T! E JBL低音炮ARRAY 1500 2颗
U! u" \! C" c" D
8 _8 I% C \5 n2 L( m5 m0 ?- e JBL入墙环绕S4AI THX 8只6 L# C J# e6 i. A* m
& y8 t/ e4 y, R; Y JBL 后级功放S820 THX 1台
3 s+ u0 A" A) I+ G/ j& c5 Z) ]8 j, a$ n
Integra 后级功放70.1 THX 1台
5 N! G1 d- u, M5 h' F! P% k# }, ~! l& v% Z. }
Integra 前级解码器80.6 THX 1台
' \7 V$ y" y# {9 J9 ?2 T- K- q2 Y, \% ]: m0 X
OPPO 蓝光播放器DBP-105D 1台
+ F" k# ]+ f5 y0 A( @# u9 y9 U' K3 r7 Y# W4 S/ b8 B- g
EPSON投影机ls10000 1台
4 P# \+ q: K& L* z1 C; r3 T6 s# e. z* |6 _9 v/ x
Screen Research184英寸16:9 画框透声白幕1块 |
