会议控制主机
' y) m o$ i9 v7 ~' R4 e, f ◆具会议单体声音白我测试功能。% e/ C* }- I0 B" U& B9 y6 P- j
◆自动关闭模式具5段可选择。开啟单体未发言超过30/40/60/90秒自动关闭(主席不受限制)。' D0 {1 S- s* B+ Z' e: J
◆具主席专用发言模式、会议暂停模式及限制计时模式《限制会议单 体可发言时间及次数)。
1 b$ Q& `9 f6 T C ◆开放模式具5段可选择,1-9支会议单体同时发言。4 }* E. C# H' u- Q7 Q, K! }
◆具分配侦测器(固定于桌下或墙面)用于干贱回路分配及连接会议 单体可指示干贱及电压侦测功能。
3 }: Y3 q( d. ^2 i3 B3 F ◆具会议麦克风光环显示控制电路联机自我测试功能(亮:正常, 不亮:故障)。1 h7 C/ x$ b( Q4 V1 T. N
◆以上功能可由主机或主席单体随时改弯会议模式应变现场状况。, Q1 C" R3 s# [- A7 ?
. I: V4 C& Y- V+ {
$ t+ M3 b3 H% D7 t
Main Power Amplifier" t% N; K" h) j$ e) A
"With conference unit sound self-testing function.
0 W+ s* Z, z; S! V( t7 V. Z9 Z* ] "Auto-turn off mode has 5 segments optional,open unit over 30/40/60/90 seconds without speaking will turn off automatically (Chairman Unit unlimited),. u4 X/ P& D& H( F
"With specialized in Chairman Unit Mode, Conference Pause Mode and Limited Timing Mode (To limit time and times for conference unit to speak).1 r* y6 ?: d I" G) {
"Open mode has 5 segments optional,1-9 conference unit speaks at the same time., P; N0 X# V0 o" u; O! S
"With distribute check unit(fixed under the desk or on the wall),use to distribute the trunk line loop and connectto the conference unit, can indicate the trunk line* R1 ?$ F% C& g D* F
and voltage check function.
% ]0 E+ y% w/ W "With the self-testing function of conference microphone halo indication control the circuit connect to the machine (Bright: Normal, unbright:malfunction).! j$ S6 r1 x* ^# g5 r% G' c: I0 r" L
*The adove functions can change the conference mode at any moment by the main unit or chairman unit to meetthe current situation.
1 m, N5 X- V* ]2 _) V3 m数字会议系统YM-5000数位AV主机介绍;
2 j3 c, q- i$ F 1、 以高性能CPU為核心的嵌入式硬件架构,系统更稳定,运算更快捷
: c( ~! u X+ N- n 2、音频信号釆用专用的高性能DSP进行处理,输出音频的效果接近CD音质,与会代表可以听到清晰流畅的语音,会议交流将更轻松愉快$ H% k2 F4 g/ u
3、PC与会议控制主机之间采用先进的RS232连接控制方式,可以实现会议系统的远程控制、远程诊断、远程升" N5 P' f8 F8 @5 s9 h* O
4、每个9PIN主列席可最多接32个主列席,主列席可任意放置。- n3 B& V$ l4 O) S! c' M4 ~
5、1个9PIN232公座,连接摄象机主机
' R4 N0 V% D% O$ H! o- @ 6、1个9PIN 232公座,连接麦克风扩展主机: N0 O1 G: q3 ~
7、1个9PIN232公座,连接PC$ ]! a4 D! W3 w2 e# f
8、具备多种音频信号输入输出方式:
9 ]. ~4 A) ^+ G; } 9、发言模式可选择:自动、1. 3, 6.9列席四种模式。: C* n7 `! o- `4 m [
10发言待机时间可选择:自动、30秒、45秒、60秒、90秒。
! ]1 I, u8 F' j( G |
