KRK V6 S4技术规格 5 s5 t9 t3 y, y
配置:两分频有源监听音箱
& _$ [7 W9 @# R7 {7 @5 C. F6 z) S系统类型:Active Studio Monitor ' }2 K: g( z7 o+ Y6 D0 _
低频:低音单元,6.5“铸铝框架,凯夫拉锥体,铁氧体磁铁 + Z0 @$ l' G. U
高频:高音单元,1“,凯夫拉尔圆顶,铁氧体磁铁
! S Z4 a- d9 [2 I: L7 `频率响应:49Hz - 19kHz 4 @8 c( T/ ~7 E6 |. W# }5 Y
频率范围:40Hz?24kHz , k8 `: z0 K& R* D) H) Y
最大峰值SPL:115 dBSPL
* {' T" U# R' r0 ?: F0 L. x- o功率输出:LF(125瓦),HF(30瓦),总计(155瓦) 5 A( n1 `" O3 h
高频控制:H1 (High Shelf -2dB 10kHz, H2 (High Shelf -1dB 10kHz / High Mid Peq -1dB 3.5kHz), H3 (High Mid Peq -1dB 3.5kHz), H4 (Flat), H5 (High Mid Peq +1dB 3.5kHz), H6 (High Shelf +1dB 10kHz / High Mid Peq +1dB 3.5kHz, H7 (High Shelf +2dB 10kHz) $ ^8 U5 R& R N. w
低频控制:L1 (Low Shelf -3dB 60Hz), L2 (Low Shelf -1.5dB 60Hz), L3 (Low Shelf -2dB 60Hz / Low Mid Peq -2dB 200Hz), L4 (Flat), L5 (Low Mid Peq -2dB 200Hz), L6 (Low Shelf +1.5dB 60Hz), L7 (Low Shelf +3dB 60Hz) $ ~4 f, r3 j1 f# y3 |( A9 ~
外壳结构:MDF /铝 / y/ x: ^* ]8 j$ g# [: n7 Y
尺寸(高x宽x深):13.89“(353mm)×9.09”(231mm)×11.34“(288mm)
3 C2 Y% x" u i3 [, o重量:20.72Lbs。 (9.4公斤) |
