Vacuum Tube 24 Bit/HDCD CD Player
Model : CDP-8HT
Dimension (DxWxH) : (360 x 440 x 75) mm
Output Level: Transistor Output 2V (Fixed) / Vacuum Tube Output 2V (Fixed)
Digital Coaxial Output: According to the S/PDIF standard
System:
Frequency Response: 2 - 20KHz /- 0.5dB
S/N: > 104 dB (Transistor Output) / > 96dB (Vacuum Tube Output)
Dynamic Range: > 104dB
Channel Separation: > 96dB
Total Harmonic Distortion: < 0.002% (1KHz)
Power Requirements: AC220-240V / 50-60Hz
Power Consumption: < 80 Watts
Operating Temperature: 5/-40 celsius degree
Operating Humidity: 5-90% (provided that no condensation forms)
IC: CS8414 x 1, BB-OPA2134 x 1
Transport:
Vacuum Tubes: Sovtek 6922 (6DJ8) x 2
CDP-8HT超薄超重量级Hi-End胆CD机,采用美国BB公司最新优质PCM-1732(24 Bit / 96 KHz带HDCD)解码及D / A转换功能集成电路,低通滤波及输出亦采用同厂着名发烧级OPA-2134运算放大IC、SOVTEK 6922低噪音名胆及美国发烧级Multicap作为交连电容;而CD则取PHILIPS之CDM-12机芯及CD7-mkII SERVO电路,令音色层次感、音乐感,音场定位、动态及整体操作配合表现更佳,Hi-End品味更能突显 ? 附设晶体管及真空管两组独立音频输出,是当今可满足无论是喜欢「胆声」或「原子粒声」发烧朋友们之唯一选择,且附有同轴及光纤输出、遥控装备,功能一应俱全!
