音频信号处理装置_论坛事务_音频应用论坛 - Powered by AUIOAPP
[资讯] 音频信号处理装置
daladana 发表于 2016-1-9 10:25:07
音频信号处理装置
BACKGROUND OF THE INVENTION 发明背景
[0001] 1. Field of the Invention 本发明的[0001] 1。场
[0002] The present invention relates to an audio signal [0002]本发明涉及一种音频信号
processing device Which processes audio signals and outputs 它处理的音频信号和输出处理装置
the audio signals and, more particularly, to an audio signal 的音频信号,更具体地说,涉及一种音频信号
processing device characteriZed by control of display on a 通过显示器上的控制特点处理装置
display portion. 显示部分。Further, the invention relates to a program 进一步地,本发明涉及一种程序
for making a computer controlling the audio signal process 用于使计算机控制的音频信号处理
ing device perform such a control. ING装置进行这样的控制。
[0003] 2. Description of the Related Art 背景技术[0003] 2。描述
[0004] Conventionally, in an audio signal processing [0004]通常,在音频信号处理
device such as a digital mixer Which processes audio signals 设备,如数字调音台用于处理音频信号
and outputs the audio signals, indicators have been provided 并输出音频信号,指标已经提供
near corresponding setting controls for setting values of 附近相应的设置控制设定值
parameters for the signal processing to display the values of 用于信号处理的要显示的参数值
the parameters set by the controls (see US. 2002/0156547 由控制参数设置(见美国2002/0156547
A1, particularly FIG. A1,尤其是图8 of the draWings and section 0061 in 在8图纸和部分0061的
the description). 的说明)。
[0005] As the aforementioned indicator, an indicator is [0005]作为上述指标,一个指标是
used that presents information by presence or absence of 用于呈现由存在或不存在的信息
lighting of a light source such as an LED (light emitting 的光源,例如LED(发光的照明
diode). 二极管)。For eXample, for a digital miXer described in above 例如,对于一个数字混频器在上述
described document, it is described that many LEDs are 描述的文档中,描述了许多LED是
arranged around a dial-type control and used as indicators 围绕着一个表盘式控制和使用的指标
indicating a value set by the control. 表示由所述控制设置的值。In this case, When the 在这种情况下,当
value of the parameter is changed by operation of the 该参数的值由操作改变
control, the LEDs are turned on or turned off to indicate a 控制,这些LED被导通或关断,以指示
neW value after the change. 改变后的新值。
[0006] Further, there is also a knoWn mixer that is pro [0006]此外,还存在一种已知的混频器,是亲
vided With a function of storing a set of values of parameters 封面加存储的一组参数值中的一个函数
used for the signal processing as scene data and recalling this 用于信号处理的作为场景数据,并回顾这
in accordance With operation of an operator. 按照操作者的操作。Also in perfor 此外,在PERFOR
mance of such a recall, the values of the parameters might 这样的召回曼斯,该参数的值可能
be changed from the values before the recall, and therefore 从回收前的值改变,因此
When the values are changed, the LEDs are turned on or 当该值被改变时,LED被导通或
turned off to indicate neW values after the change. 关闭后的变化来表示新值。
[0007] There are conceivable use environments of the [0007]还有的可以想象的使用环境
digital miXer including not only a bright place such as the 数字调音台不仅包括一个明亮的地方,如
outdoors during the daylight hours but also a dark place such 室外在白天也是一个黑暗的地方,例如
as the inside of a concert hall With the illumination turned 作为音乐厅随着照明里面翻
off. 关。Even in such a dark place, the set contents of the 即使在这样的暗处,的设置内容
parameter can be optically easily grasped by providing the 参数可以通过提供可光学容易掌握
aforementioned indicators implemented by the LEDs. 通过LED实现上述指标。
[0008] HoWever, the display portion in such a conven [0008]然而,在这样一个公约的显示部
tional digital miXer simply displays the set value of the 周志武,数字调音台只是显示的设定值
parameter at the time of performing display. 参数在执行显示的时间。This con?gu 这con?区
ration presents no particular problem When the display is 理性并没有任何特别的问题当显示器
performed in accordance With the change in the value of the 按照的值的变化进行
parameter by the operation using the control. 参数使用控制操作。This is because 这是因为
the operator of course grasps What parameter he or she 当然,操作人员抓住什么参数,他或她
changed, and the changes are performed step by step in this 改变,并且变化是逐步执行在此
case, so that the operator can easily grasp hoW the parameter 情况下,使操作者能够容易地掌握如何将参数
Was changed as a Whole as Well as the current value. 被改变为一个整体,以及电流值。
[0009] HoWever, there has been a problem at the time [0009]然而,存在于时间一直是一个问题
When many settings are changed in an instant such as When 当许多设置都在瞬间如当改变
the scene data is recalled. 场景数据被调出。More speci?cally, in such a case, 更SPECI?和Cally,在这种情况下,
the values of the parameters before the recall Will be 此次召回之前的参数值将被
displayed before the recall and the values of the parameters 参数的召回和值显示之前
Sep. 16, 2004 2004年9月16日
relating to the recalled scene data Will be displayed after the 涉及召回的现场数据将后会显示
recall, but there has been a problem that it is difficult for the 回想一下,但出现了一个问题,即难以在
operator to grasp, even taking a look at the display after the 运营商掌握,甚至采取一看后在显示器上
recall, hoW and What parameters Were changed by the recall 回想一下,如何和什么参数的召回发生了变化
of the scene data. 的场景数据。Although it is possible to have some grasp 虽然它可能有一些把握
by comparison betWeen the displays before and after the 通过比较前,后之间的显示
recall, typically the controls are considerably large in num 召回,通常的控制是相当大的民
ber in the digital miXer, and therefore it is considerably 误码率的数字混频器,因此它是相当
difficult to grasp the presence or absence and the degree of 难以把握的存在与否和程度
change and memoriZe all of them at the instant of the recall. 改变和背诵所有的人都在回忆的瞬间。
[0010] To solve the aforementioned problems, there is also [0010]为了解决上述问题,也有
a knoWn digital miXer including a function of changing only 一个已知的数字调音台,包括只改变一个函数
the display to that based on the scene data before the recalled 显示器,基于回忆之前的场景数据
scene data is re?ected in the signal processing so as to be 场景数据是重?ected在信号处理,以便
able to verify in advance the values of the parameters 能够验证提前参数的值
relating to the scene data. 有关的场景数据。In the case of a device including 在其中一个装置的情况下
such a function, it is possible to verify, before the actual 这样的功能,它可以验证,在实际
change of the contents of the signal processing, to What 变化的信号处理的内容,以什么
values the values of the parameters Will be changed, thus 值的参数的值将被改变,从而
reducing the risk of recalling Wrong scene data and per 减少错误的回忆场景数据的风险,并每
forming Wrong signal processing. 形成错误的信号处理。Besides, several times 此外,多次
changes and comparisons betWeen the display of the cur 变化之间的电流的显示对比
rently set values of the parameters and the display of the 的参数和的显示器的rently设定值
values of the parameters relating to the scene data make it 与现场数据的参数值,使其
possible for the operator to have some grasp hoW the 可能对操作者有一定的把握如何
parameters Will be changed by the recall of the scene data. 参数将通过现场数据的召回而改变。
The operation, hoWever, is troublesome and time consuming 的操作,但是,很麻烦和费时的
and, in addition, once the scene data is re?ected in the signal 并且,此外,一旦场景数据是重?ected的信号中
processing, the operator needs to remember the changed 处理过程中,操作者必须记住的变
parts. 部分。
[0011] In an actual use of the digital miXer, it has been [0011]在实际的使用数字调音台,它一直
often performed that a plurality of scene data With the values 常执行的多个场面的数据用的值
of only a part among many parameters being changed are 只有被改变在许多参数的部分是
created and recalled in sequence for use, and there has been 创建和调用顺序使用,并出现了
a strong demand to grasp Where the values of the parameters 强烈要求把握其中的参数值
relating to the recalled scene data are different from the 与该调用场景数据是从不同
values set before the recall, but the conventional digital 回忆之前设置的值,但传统的数字
miXers could not sufficiently meet the demand as described 混合器不能充分满足需求的描述
above. 以上。
SUMMARY OF THE INVENTION 发明内容
[0012] It is an object of the present invention to solve the [0012]在本发明的一个目的是解决
above-described problems and to con?gure an audio signal 上面描述的问题和对Con?GURE的音频信号
the audio signals such that When a value of a parameter 的音频信号,使得当一个参数的值
stored therein is loaded, part of the value of the parameter 存储在其中被加载时,该参数的值的一部分
changed from the value at the time of the loading and part 从值改变在装载和部分的时间
thereof not changed can be easily distinguished. 它们不会改变可以很容易地分辨。
[0013] To attain this object, the invention is an audio [0013]为了达到这个目的,本发明是一种音频
signal processing device Which processes audio signals and 它处理的音频信号及信号处理装置
outputs the audio signals Which comprises: controls for 输出的音频信号,它包括:用于控制
setting values of parameters of the signal processing; 设置的所述信号处理的参数值;a 一
display for presenting a set value of the parameter; 显示用于呈现该参数的一组值;a 一
memory for storing a value of the parameter; 存储器,用于存储所述参数的值;a loader for 一辆装载机
loading the value of the parameter stored in the memory; 加载存储在存储器中的参数的值;a 一
comparator for comparing, When the loader loads the value 比较器,用于比较,当装载器装载值
of the parameter, a value of the parameter set at a time of the 参数,该参数的值设定为在一个时间
loading With the loaded value of the parameter; 加载随着参数的加载值;and a display 以及显示
controller for making a display style on the display different 控制器为显示屏上的不同使得显示器的风格
in accordance With a comparison result on match/mismatch 按照上匹配/不匹配的比较结果
by the comparator. 由比较器。
[0014] Further, the invention is an audio signal processing [0014]此外,本发明是一种音频信号处理
device Which processes audio signals and outputs the audio 装置,其处理音频信号,并输出音频
Page 11 第11页
US 2004/0179695 A1 US 2004/0179695 A1
signals Which comprises: controls for setting values of 信号,它包括:控制用于 设置的值
parameters of the signal processing; 信号处理的参数;a display for presenting 一个显示器,用于显示
a set value of the parameter; 该参数的一组值;a memory for storing a value 用于存储值的存储
of the parameter; 参数;a loader for loading the value of the 一辆装载机装载的价值
parameter stored in the memory; 参数存储在存储器中;and a display controller for 和一个显示控制器
making, When the loader loads the value of the parameter, 使得,当加载器加载的参数的值,
the display simultaneously present the loaded value of the 显示器同时呈现的加载值
parameter and a value of the parameter set at a time of the 参数和所述参数的值设定为在一个时间
loading in different display styles. 在加载不同的显示风格。
[0015] In such an audio signal processing device, it is [0015]在这样的音频信号处理装置,它是
preferable that the display is provided With a light source 优选地,所述显示器被设置有光源
capable of lighting up in a plurality of styles. 能够发光的多个样式。Further, it is 另外,也
preferable that the light source is a light emitting diode. 优选的是,所述光源是发光二极管。
Further, it is preferable that lighting brightness of the light 另外,优选的是,光的照明亮度
source is different for each of the display styles. 源是对每个显示样式不同。Further 进一步
more, it is preferable that the display is made to present the 更多,优选的是,该显示器被做成呈现
value of the parameter set at the time of the loading at a 设置在装载的时候在一个参数的值
loWer brightness than the loaded value of the parameter. 低亮度比参数的加载值。
[0016] Alternatively, it is preferable that lighting color of [0016]可选地,优选的是,照明颜色
the light source is different for each of the display styles. 光源是对每个显示样式不同。
[0017] It is also preferable that the display is a display for [0017]还优选的是,显示的是显示器,用于
presenting continuous values. 呈现连续值。In this case, it is preferable 在这种情况下,优选
that the display is made to present an overlapped part and a 该显示器是向目前的重叠部分和一个
different part betWeen the value of the parameter set at the 不同部分之间的参数设定为值
time of the loading and the loaded value of the parameter in 装载和在参数的加载值的时间
different display styles. 不同的显示风格。Further, it is preferable that the 另外,优选的是
display is made to present the overlapped part and the 显示器被做成呈现重叠的部分和
different part using a ?rst display style and a second display 使用?RST显示样式和第二显示不同的部分
style that is less conspicuous than the ?rst display style. 风格,是不是?RST显示风格不太显眼。
[0018] Furthermore, it is preferable that When the loaded [0018]此外,优选的是,当所加载的
value of the parameter is larger than the value of the 该参数的值比的值大
parameter set at the time of the loading, the display is made 参数设置在装载的时候,显示的是由
to present the overlapped part in the second display style and 呈现的重叠部分在所述第二显示样式和
the different part in the ?rst display style. 不同的参与?RST显示样式。Alternatively, it is 可替代地,它是
preferable that When the loaded value of the parameter is 优选的是,当参数的加载值是
smaller than the value of the parameter set at the time of the 大于该参数的设定的时间值越小
loading, the display is made to present the overlapped part 加载时,显示是向目前的重叠部分
in the ?rst display style and the different part in the second 在πRST显示风格并在第二不同部分
display style. 显示风格。
[0019] Further, it is preferable that the above-described [0019]此外,优选的是,上述
audio signal processing device further comprises an instruc 音频信号处理装置还包括一个指令
tor for providing an instruction not to re?ect the value of the 器提供的指令不重新?ECT的价值
parameter loaded by the loader in the signal processing, in 参数由加载器加载的信号处理,在
Which When the instruction has been provided by the instruc 其中当指令已经由指令提供
tor at the time of the loading of the value of the parameter, 器的参数的值的负载时,
the loaded value of the parameter is not re?ected in the 该参数的加载值不重?ected在
signal processing. 信号处理。
[0020] Further, the invention is a computer program con [0020]此外,本发明是一种计算机程序浓度
taining program instructions executable by a computer and 泰宁程序指令可由计算机执行,并
causing the computer to execute: a process of processing 使所述计算机执行以下处理:处理的流程
audio signals and outputting the audio signals; 音频信号,并输出该音频信号;a process of 的处理
setting values of parameters of the signal processing in 中设置的所述信号处理的参数值
accordance With operation of controls; 按照控制操作;a process of making 制作的过程
a display present a set value of the parameter; 显示器呈现参数的一组值;a process of 的处理
storing a value of the parameter; 存储所述参数的值;a process of loading the 加载的过程中,
value of the parameter stored in the storing; 存储单元中存储的参数值;a process of 的处理
comparing, When loading the value of the parameter in the 相比较,当在加载参数的值
loading, a value of the parameter set at a time of the loading 加载,所述参数的值设置在装载的时间
With the loaded value of the parameter; 用参数的加载值;and a process of 和的过程
making a display style on the display different in accordance 按照显示屏上的不同使得显示器的风格
With a comparison result on match/mismatch by the com 随着匹配/不匹配的COM的比较结果
paring. 配对。
[0021] Further, the invention is a computer program con [0021]此外,本发明是一种计算机程序浓度
value of the parameter stored in the storing; 存储单元中存储的参数值;and a process of 和的过程
making, When loading the value of the parameter in the 使得,当装载于该参数的值
loading, the display simultaneously present the loaded value 加载中,同时显示目前装载值
of the parameter and a value of the parameter set at a time 的参数和参数组的值在一个时间的
of the loading in different styles. 加载中不同的风格。
[0022] The above and other objects, features and advan [0022]上述和其它目的,特征和ADVAN
tages of the invention Will be apparent from the folloWing 本发明的每日新闻将是显而易见的下面
detailed description Which is to be read in conjunction With 详细说明哪些是要结合阅读
the accompanying draWings. 附图中。
BRIEF DESCRIPTION OF THE DRAWINGS 附图的简要说明
[0023] FIG. [0023]图1 is a vieW shoWing a con?guration example 1是表示一个反面?guration例子
of a console of a digital mixer being an embodiment of an 一个数字混频器作为一个的一个实施例的控制台
audio signal processing device of the invention; 音频信号处理本发明的装置;
[0024] FIG. [0024]图。2 is a block diagram shoWing a con?guration 2是一个框图,显示一个反面?guration
of the digital mixer; 数字调音台;
[0025] FIGS. [0025]图。3A and 3B are vieWs each shoWing a 图3A和图3B是各自示出了
display example at a ?lter value display portion of a ?lter 例如显示在滤池的?滤波器值显示部分
operation section, for explaining a display style at the 操作部,用于在说明显示样式
display portion provided in the digital mixer; 在数字混频器提供显示部分;
[0026] FIGS. [0026]图。4A and 4B are similar vieWs each shoWing 4A和4B是相似的看法每个显示
a display example at a group display portion of a fader 在一组显示推子部分的显示例
operation section; 操作部分;
[0027] FIGS. [0027]图。5A and 5B are similar vieWs each shoWing 5A和5B是相似的看法每个显示
a display example at a group ON/OFF display portion of a 在一组的开/关显示部的显示的例子
group operation section; 组操作部;
[0028] FIG. [0028]图6 is a ?oWchart shoWing a characteristic part 6是?oWchart呈现出特色的部分
of processing relating to display in the digital mixer shoWn 的处理有关的数字调音台显示以
in FIG. 图。2 and a change betWeen display styles thereof; 2之间的显示风格及其变化;
[0029] FIG. [0029]图7 is a ?oWchart shoWing scene data recall 7是?oWchart显示现场数据调用
processing shoWn in FIG. 处理的图。6; 6;and 和
[0030] FIG. [0030]图。8 is a vieW for explaining storage forms and 图8是用来说明存储形式和
processing contents in a setting buffer, a veri?cation buffer, 在设置缓冲处理内容,一个VERI?阳离子缓冲液,
and a scene memory. 和场景记忆。
DETAILED DESCRIPTION OF THE 的详细描述中
PREFERRED EMBODIMENTS 具体实施方式
[0031] Hereinafter, preferred embodiments of the inven [0031]在下文中,优选的inven的实施方案
tion Will be described With reference to the draWings. 化将参照附图进行说明。
[0032] Acon?guration of a digital mixer being an embodi [0032]艾康?guration数字调音台作为一个embodi的
ment of an audio signal processing device according to the 的音频信号处理装置的换货
invention Will be described ?rst. 发明进行说明?RST。FIG. 图。2 is a block diagram 图2是一个方框图
shoWing the con?guration of the digital mixer. 显示该con?guration的数字调音台。
[0033] The digital mixer (hereafter, also referred to simply [0033]在数字混频器(以下,也简称
as a “mixer”) is an audio signal processing device Which 作为“混合机”)是一个音频信号处理装置,其
performs various kinds of signal processing such as mixing, 进行各种信号处理,诸如混合,
equalizing, and so on for inputted audio signals in accor 均衡,等等用于在雅输入的音频信号
dance With set parameters and outputs the audio signals, in 跳舞设定参数和输出音频信号,在
Which, as shoWn in FIG. 其中,如图所示。2, a CPU 111, a ROM 112, a RAM 如图2所示,CPU 111,ROM 112和RAM
113, a display circuit 114, a detection circuit 115, a digital 113,显示电路114,检测电路115,一个数字
Page 12 第12页
signal processor (DSP) 116, and a communication interface 信号处理器(DSP)116,以及通信接口
(UP) 120 are connected to a system bus 121. Further, a (UP)120连接到系统总线121,此外,一
display 117, controls 118, and an input/output UP 119 are 显示117,控制118,和输入/输出高达119顷
connected to the display circuit 114, detection circuit 115, 连接到显示电路114,检测电路115,
DSP116, respectively. DSP116分别。
[0034] The CPU 111 is a control unit that comprehensively [0034]处理器111是一个控制单元,全面
controls operation of the Whole mixer and also executes a 控制整个调音台的操作,并执行
predetermined program stored in the ROM 112 to thereby 预定的程序存储在ROM 112,由此
control read and Write of data in the ROM 112 and RAM 控制和读取在ROM 112写入数据的和RAM
113, display on the display 117 by the display circuit 114, 113,显示由显示电路114在显示117上,
detection of operation at the controls 118 by the detection 检测动作的控件118由检测
circuit 115 and change of values of parameters accompany 电路115和参数值的变化伴随
ing the change, signal processing in the DSP 116, commu ing的变化,信号处理在DSP 116,COMMU
nication With external devices via the communication UP 通过通信UP nication与外部设备
120, and so on. 120,依此类推。
[0035] The ROM 112 is a non-volatile memory that stores [0035]该ROM 112是一种非易失性存储器,其存储
a control program executed by the CPU 111, and so on. 通过CPU 111的控制程序来执行,等等。
[0036] The RAM 113 is a memory that includes a later [0036]该内存113是包括后的存储器
described setting buffer and veri?cation buffer provided 描述设置缓冲区和VERI?阳离子缓冲提供
therein to store temporarily necessary data such as values of 在其中存储临时需要的数据,如值
parameters set in the mixer and is used as a Work memory 在混频器设置参数和被用作工作存储器
of the CPU 111. Further, a part of the RAM 113 is a 在CPU 111中,另外,在RAM 113的一个部分是一个
reWritable non-volatile memory such as an EEPROM, in 重写的非易失性存储器,例如EEPROM,在
Which a later-described scene memory is provided to store 其中,后述的场景存储器,其存储
scene data. 场景数据。
[0037] The display circuit 114 is a circuit that controls [0037]所述的显示电路114是用于控制电路
display on the display 117 based on control data sent from 显示基于从发送控制数据的显示117上
the CPU 111. The con?guration of the display 117 Will be 在CPU 111。该con?guration显示器117将
described later in detail. 在后面详细说明。
[0038] The detection circuit 115 is a circuit that detects [0038]所述的检测电路115是检测电路
operation in the controls 118 based on the control by the 在基于由控制控件118的操作
CPU 111. The con?guration of the controls 118 Will be CPU 111,该con?guration控制118将是
described later; 后面描述;the display 117 and the controls 118 can be 显示器117和控制118可
con?gured as an integral console panel. CON?gured作为一个整体控制台面板。
[0039] The DSP 116 is a circuit that performs various [0039]该DSP 116是执行各个电路
kinds of signal processing including mixing and equalizing 种信号处理,包括混合和均匀化
according to set values of various parameters for audio 根据设定的各种参数进行音频的值
signals inputted through the input/output UP 119, and the 信号通过输入/输出输入UP 119和
input/output UP 119 is an interface for receiving input of 输入/输出高达119是用于接收输入的接口
audio signals to be processed in the DSP 116 and outputting 音频信号,以在DSP 116进行处理,并输出
the processed audio signals. 处理后的音频信号。
[0040] The communication UP 120 is an interface for [0040]通信UP 120是一个接口
communicating With an external device such as a personal 通信与外部设备,例如个人
computer (PC). 计算机(PC)。Further, the mixer can output the audio 另外,混频器可以输出音频
signals that have been processed by the DSP 116 to the 已处理由DSP 116的信号
external device, operate in accordance With control by the 外部设备时,操作按照由控制
external device, and doWnload programs from the external 从外部外部设备,并下载程序
device to make the CPU 111 execute the programs. 装置,使CPU 111执行的程序。
[0041] A con?guration of a console in Which the display [0041]阿con?guration控制台,其中显示
117 and controls 118 of the digital mixer are arranged Will 117和控制数字混频器118被布置威尔
be described next. 进行说明。Acon?guration example of the console is 控制台艾康?guration的例子是
shoWn in FIG. 如图所示。1, in Which the con?guration is simpli?ed so 1,其中CON?guration是简化?这么编
that only characteristic parts are shoWn for convenience of 只有特征部分示出了方便的
illustration, and actually much more controls and display 插图,实际上更多的控制和显示
portions are often arranged. 部分往往安排。
 楼主| daladana 发表于 2016-1-9 10:25:46
[0042] This console includes, as shoWn in FIG. [0042]该控制台包括,如该图所示。1, a ?lter 1,一个滤池
operation section 10, a fader operation section 20, a group 操作部10,衰减器的操作部分20,一组
operation section 30, a scene recall operation section 40, and 操作部分30,一个场景重调用操作部40,和
a display panel 50. 一个显示面板50。
[0043] Further, the ?lter operation section 10 includes [0043]此外,在滤波器操作部10包括
?lter controls 11, ?lter range indicators 12, and ?lter value 滤池控制11,滤池范围指标12,和滤池的价值
display portions 13. FIG. 显示部13的图。1 shoWs an example in Which three 图1示出一个例子,其中3
sets of these components are provided. 提供集这些组件。
[0044] The ?lter control 11 is a dial-type setting control [0044]该滤池控制11是拨号类型设置控制
for setting a parameter of the output level of each frequency 用于设定各频率的输出电平的参数
range by turning to the right With a minimum value at a 范围内转动到右侧用在一个最低值
position of a pointer 11a corresponding to LOW in FIG. 在图对应于低的指针11a的位置。1 1
and a maximum value at a position of a pointer correspond 以及在指示器的位置的最大值对应
ing to HIGH. ing到高。
[0045] The ?lter range indicator 12 is an indicator includ [0045]该滤池范围指示器12是一个指标INCLUD
ing a liquid crystal display (LCD), for displaying a fre ing一个液晶显示器(LCD),用于显示一个频率
quency range for Which the setting of the ?lter is performed 对于其中执行滤池的设定频率范围
by the ?lter control 11. For example, the ?lter range indi 由滤池控制11。例如,滤池范围悠
cator 12 on the most left side in FIG. 示器12上的最左侧所示。1 shoWs that the 图1示出了
corresponding ?lter control 11 is a control for setting the 对应滤池控制11是用于设定一个控制
output level of a loW frequency range. 一个低频范围的输出电平。
[0046] The ?lter value display portion 13 is a display [0046]该滤池值显示部分13是一个显示
portion including a light source constituted of an LED LED的部分,它包括一个光源构成
capable of lighting-up at a ?rst brightness and a second 能够亮灯在?RST亮度和第二
brightness loWer than the ?rst brightness for each of lighting 亮度比?RST亮度为每个照明低
elements that are shoWn by circles in FIG. 这由图圆圈中所示的元件。1 to present 1提出
information of the value of a parameter of the output level 的输出电平的参数值的信息
set by the corresponding ?lter control 11 by the presence or 通过相应的滤波器控制11的存在或设置
absence and the style of the lighting. 缺席和照明的风格。
[0047] The fader operation section 20 includes fader con [0047]推子操作部分20包括推子CON
trols 21, fader channel indicators 22, group setting controls 进行操纵21,推子通道指标22组设置控制
23, and group display portions 24. FIG. 23,和组显示部分24。图。1 shoWs an example 1显示了一个例子
in Which ?ve sets of these components are provided. 在哪?已经提供集这些组件。
[0048] The fader control 21, Which is a slide-type control, [0048]推子控制21,这是一个滑动式控制,
is a setting control for setting the parameter of the input level 是用于设置输入电平的参数设置控制
or the output level of a channel allocated thereto. 或分配一个通道的输出电平于此。
[0049] The fader channel indicator 22 is an indicator [0049]推子通道指标22是一个指标
including an LCD for displaying a channel for Which the 包括LCD用于显示哪一个通道
level is set by the fader control 21. For example, the fader 级别由推子控制21集。例如,推子
channel indicator 22 on the most left side in FIG. 于最左侧图指示符信道22。1 shoWs 1显示
that the corresponding fader control 21 is a control for 该相应的推子控制21是用于控制
setting the input level of a ?rst input ch. 设置?RST输入通道的输入电平。
[0050] The group setting control 23 is a setting control for [0050]组设定控制23是用于设定控制
selecting What group or no group the corresponding fader is 选择哪些组或没有组相应的推子
made to belong to and is designed such that every time the 向属于与被设计成使得在每次
group setting control 23 is pressed, the parameter indicating 组设定控制23被按下时,该参数指示
the group to Which the fader Will belong changes in sequence 本集团为推子将属于变化序列
and cycles like the group 1Q2Q3QnoQ1. 而像群1Q2Q3QnoQ1周期。
[0051] The group display portion 24 is a display including, [0051]本组显示部分24的显示,包括
similarly to the ?lter value display portion 13, an LED for 类似于滤池值显示部分13,用于LED
each frame to present information of the value of a param 每一帧提出一个参数的值信息,
eter set by the corresponding group setting control 23 by the 酬酢由相应组的设置控制23集
presence or absence and the style of the lighting of the LED. 有无和LED的照明风格。
[0052] Note that no display portion is provided that pre [0052]请注意,没有显示部被提供的预
sents the information of the value of the parameter set by the 发送多的参数的值,由所设置的信息
fader control 21 in the mixer, and it is not alWays necessary 在推子调音台控制21,它并不总是必要的
to provide such a display for every setting control. 提供这样一种显示每个设定控制。As a 作为
matter of course, a display portion corresponding to the 物的过程中,对应于所述显示部分
fader control 21 may be provided. 衰减器控制21也可以提供。
[0053] The group operation section 30 includes group [0053]本组操作部30包括组
fader controls 31, group indicators 32, group ON/OFF 推子控制31组指标32组开/关
controls 33, and group ON/OFF display portions 34. FIG. 控制33,和组的ON / OFF显示部分34。图。1 1
shoWs an example in Which three sets of these components 显示了一个例子,其中三套这些组件
are provided. 提供。
 楼主| daladana 发表于 2016-1-9 10:26:00
Page 13 第13页
[0054] The group fader control 31, Which is a slide-type [0054]本组推子控制31,这是一个滑动型
control, is a setting control for changing, When a group is 控制,是不断变化的,当一组是设定控制
effective, the values of parameters set by all the faders 有效的参数值由所有推子设置
belonging to the group all at once by the same amount. 相同金额属于该组的一次。
When the group is in effective, the group fader 31 does not 当组是有效的,该组推子31不
particularly participate in setting, and therefore the value of 特别是参与制定,因此价值
the parameter of the fader is set only by the fader control 21 推子的参数只能由推子控制21集
in the fader operation section 20. 在推子操作部分20。
[0055] The group indicator 32 is an indicator including an [0055]本组指标32是一个指标包括
LCD, for displaying a group for Which the level is set by the 液晶显示器,用于显示一组的量,电平是由设置
group fader control 31. For example, the group indicator 32 组推子控制31。例如,该组指标32
on the most left side in FIG. 于最左侧图。1 shoWs that the corresponding 图1示出了相应的
group fader control 31 is a control for setting the values of 组推子控制31是设置的值的控制
the parameters of a ?rst group. 一?RST组的参数。
[0056] The group ON/OFF control 33 is a setting control [0056]本组ON / OFF控制33是设定控制
for setting a parameter of the corresponding group being 用于设定对应的基团是一个参数
effective/ineffective and is designed such that every the time 有效/无效以及被设计成使得每一个时间
group ON/OFF control 33 is pressed, a change is made 组ON / OFF控制33被按下时,一个变化是由
betWeen ON (effective) and OFF (ineffective) alternately. 之间开(有效)和OFF(无效)交替进行。
[0057] The group ON/OFF display portion 34 is a display [0057]本组开/关显示部34的显示
portion including, similarly to the ?lter value display portion 部分,包括类似于滤池值显示部分
13, an LED to present information of the values of param 13,一个LED当前的参数值的信息
eters set by the corresponding group ON/OFF control 33 by 通过相应的组ON / OFF控制33集由eters
the presence or absence and the style of the lighting of the 存在或不存在和的照明样式
LED. LED。
[0058] The scene recall operation section 40 includes [0058]该场景调用操作部分40包括
scene selection switches 41 to 43 and a preview key 44. 场景选择开关41〜43和预览键44。
[0059] This mixer stores a set of values of parameters to [0059]该混频器将所设置的参数值,以
be re?ected in signal processing by the DSP 116 as scene 由DSP 116进行重新?ected在信号处理中的场景
data in a scene memory being a memory. 在一个场景存储器中的数据是内存。The scene selection 场景选择
sWitches 41 to 43 are sWitches for instructing recall of the 开关41至43是开关的指示召回
scene data. 场景数据。The mixer stores here three kinds of, that is, ?rst 混频器存储在这里3种,就是?RST
to third scene data, and is thus provided With corresponding 到第三场景数据,并因此提供具有对应
three scene selection sWitches to instruct recall of them 3场景选择开关来指导他们的回忆
respectively. 分别。When one of the scene selection sWitches is 当场景选择开关之一是
pressed, the CPU 111 loads the corresponding scene data and 按压时,CPU 111的负荷对应的场景数据,并
makes setting so that the values of the parameters included 使得设置,使参数的值包括
in the scene data are re?ected in the signal processing in the 场景中的数据是重?ected在信号处理中的
DSP 116. In this case, displays on the display portions 13, DSP 116,在这种情况下,在显示部13显示,
24, and 34 are also changed in accordance With the values 24,和34也按照值改变
of the parameters. 参数。Note that it is also possible to store by a 需要注意的是,也可以存储由一个
not-shoWn control, as the scene data, the values of the 未示出的控制,现场数据的价值
parameters set by a user operating controls. 参数由用户操作控制设置。
[0060] The previeW key 44 is a control for instructing a [0060]预览键44是用于指示控制
previeW of the scene data. 预览场景数据。When the scene selection sWitch 当场景选择开关
is pressed While the previeW key is being pressed, the CPU 时按下预览键被按下时,CPU
111 changes only the displays on the display portions 13, 24, 111的变化仅在显示部分13,24的显示器,
and 34 in accordance With the values of the parameters 并根据这些参数的值34
relating to the loaded scene data Without re?ection of the 有关加载的场景数据,而无需重新?挠度的
scene data in the signal processing. 在信号处理的场景数据。Then, the operator can 然后,操作者可以
verify the contents of the scene data through the displays. 通过显示验证现场数据的内容。
Accordingly, it can be said that the previeW key 44 is a 因此,可以说,在试映键44是
control for accepting the selection Whether or not the loaded 控制,用于接受选择是否加载的
values of the parameters are re?ected in the signal process 该参数的值是重?ected在信号处理
mg. 毫克。
[0061] The display panel 50, Which is a display constituted [0061]显示面板50,这就是构成的显示
of an LCD, is for displaying a screen for referring to, 一个LCD的,是一个用于显示用于参照的画面,
changing, saving, and so on the setting of the miXer, the 改变,节约,等等混频器的设置,
operating state of the device, and so on. 该设备的操作状态,并依此类推。The parameters of 的参数
the miXer include those set on the screen of the display panel 该混频器包括那些在显示面板的屏幕上设置
50 using not-shoWn controls, in addition to those set by 50使用未示出的控制,除了那些通过设置
operation of the above-described setting controls. 上述设置可控制的操作。
[0062] In the miXer having the above-described console, [0062]在具有上述控制台调音台,
the invention is characteriZed by the style of displays on the 本发明是通过显示器上的样式,其特征
display portions 13, 24, and 34, and therefore this point Will 显示部13,24,和34,因此这一点也
be described neXt. 将描述下一步。Note that a simply mentioned “display 请注意,只是提到“显示
portion” in the folloWing description shall represent the 在下面的描述中部分“应代表
display portion including the LEDs. 显示部分包括发光二极管。
[0063] In the miXer, the display portion can be made to [0063]在混频器,显示部分,可以向
perform display of the value of the parameter in one of three 在3中的一个执行参数的值的显示
display styles such as a normal display, a special display A, 显示风格,如正常显示,特殊显示A,
and a special display B. 并特别展示B。
[0064] First, the normal display is a display style in Which [0064]首先,正常的显示是在哪一个显示风格
a current (at the point of display) value of the parameter set 参数集的一个电流(在显示器的点)的值
by the corresponding control is simply displayed. 通过相应的控制是简单地显示。When the 当
value of the parameter is changed in accordance With the 该参数的值是按照改变
operation of the control, the value after the change is 控制的操作中,改变后的值是
displayed in the normal display. 显示在正常显示。
[0065] The special display A and special display B are [0065]特殊显示A和特殊显示B是
display styles in Which When the scene data is recalled, the 在哪个样式显示在场景数据被调用时,
value of the parameter relating to the recalled scene data 涉及召回的场景数据的参数值
(neW set value) and the value of the parameter that is set at (新的设定值),以及设置在参数的值
the time of recalling (old set value) are displayed to shoW the 回顾(旧设定值)的时间显示,显示
relation betWeen the values. 关系之间的值。The special display A is a 特殊显示A是
display style shoWing that the neW set value and the old set 显示方式显示,这个新设定值和旧集
value match With each other, and the special display B is a 值特殊显示B匹配相互搭配,并且是
display style shoWing that they do not match With each other. 显示风格表明他们不相互匹配。
[0066] Speci?c eXamples of display in these display styles [0066]显示,在这些显示风格SPECI?C + +实例
are shoWn in FIG. 示于图。3A to FIG. 图3A到图5B. 5B。FIG. 图。3A and FIG. 图3A和图3B 3B
shoW display eXamples at the ?lter value display portion 13 显示显示示例在滤池值显示部分13
of the ?lter operation section 10, FIG. 该滤波器的操作部10,图4A and FIG. 图4A和图4B shoW 4B秀
display eXamples at the group display portion 24 of the fader 在组显示推子的部分24显示示例
operation section 20, FIG. 操作部20,图5A and FIG. 图5A和图5B shoW display 5B显示显示
eXamples at the group ON/OFF display portion 34 of the 在该组的开/关显示部34的例子
group operation section 30. In these draWings, the lighting 组操作部30,在这些图中,照明
elements are shoWn by black-?lled circles, patterned circles, 元素被黑?LLED圈,圈图案所示,
and holloW circles, Which represent a state of the LED 与空心圆圈,代表了LED的状态
lighting up at a ?rst brightness, a state lighting up at a second 照亮了在?RST亮度,状态照亮了在第二
brightness, and a light-out state, respectively. 亮度和光输出状态,分别为。The display at 显示在
the ?rst brightness is a ?rst display style, and the display at 的αRST亮度是?RST显示样式,并且在显示
the second brightness is a second display style that is less 第二亮度是第二显示风格,是少
conspicuous than the ?rst display style. 显眼的比?RST显示样式。
[0067] For eXample, When continuous values (including [0067]例如,当连续的值(包括
values that are actually discrete values but substantially 这实际上是离散的值,但大幅值
continuous values) are displayed as in the ?lter value display 连续值)显示为在滤池值显示
portion 13, a plurality of lighting elements are arranged 部13,多个发光元件被布置
along the movable range of the control (pointer in particular) 沿控制的可动范围(指针尤其)
so that each of the lighting elements corresponds to a value 使得每个照明元件都对应于一个值
of a parameter Where the pointer of the control points the 参数在哪里控件的指针指向的
lighting element and near there. 发光元件和附近那里。In the normal display, as 在正常的显示,如
shoWn in FIG. 如图所示。3A, display is performed by turning on at the 如图3A所示,显示是通过在转弯上执行
?rst brightness the LEDs starting from the lighting element ?RST亮度的照明元素开始的指示灯
corresponding to the minimum value to the lighting element 对应于该最小值的照明元件
corresponding to the current value. 对应的电流值。When the value of the 当的值
parameter is the minimum value, the LEDs of all the lighting 参数是最低值,所有的照明的发光二极管
elements are turned off as shoWn in FIG. 元件被关断,如图。3B. 3B。Here, the ?lter 这里,滤池
control 11 is operated clockWise to increase the value, the 控制11工作顺时针增加值时,
LEDs light up at the ?rst brightness in sequence toWard the LED亮起的?RST亮度依次向
right. 右。
[0068] In the special display A, as shoWn by a reference [0068]在特殊显示器的,因此,如参考
symbol (a) in FIG. 在图符号(一)。3A and a reference symbol (e) in FIG. 图3A和参考符号(e)所示。
 楼主| daladana 发表于 2016-1-9 10:26:16
Page 14 第14页
3B, lighting points are the same as those in the normal 如图3B所示,照明点是相同的那些在正常
display, but the LEDs are turned on at the second brightness. 显示,但在LED灯在所述第二亮度接通。
[0069]此外,特殊显示B中,做出改变
之间的X状态和Y的状态在预定的定时
在两个国家进行闪烁显示。在X状态是
状态在上面只显示新的设定值
描述正常显示,但是状态Y显示在
取决于大小关系不同的方法
之间的新的设定值和旧值集。
[0070]更多SPECI?新增Cally,当新的设定值较大
比如由在参考符号(b)该旧设定值
FIG. 图。如图3A所示,从发光元件的发光二极管对应
到最低值到相应的发光元件
旧设定值时导通在第二亮度
由此显示旧的设定值,并且LED从其向上
对应于新的设定值照明元件
被接通的?RST亮度,从而显示
新的设定值。相反,当旧的设定值越大
较新的设定值作为一个参考符号(c)所示,
从发光元件的发光二极管对应于
最小值到照明元件对应于
新的设定值被打开的?RST亮度,从而
显示新的设定值,并由此指示灯到
对应于旧的设定值照明元件是
打开在所述第二亮度,从而显示旧
设定值。然而,这两种情况下是相同的,旧的
设定值是由照明元件的字符串显示
在第二亮度和新的设定值已开启
由照明元件是一个字符串显示
打开在?RST亮度。
[0071]此外,当新的设定值是最低的
值,只有老设定值显示为特殊
显示一个标注符号(D)如图所示,和反对
反过来,当旧的设定值中的最小值,则
显示部分的所有照明元件的LED是
关闭,如图由图的参考符号。3B. 3B。
[0072]在所执行的特殊显示B当
旧的设定值和新的设定值不匹配随着每
另外,最好是显示新旧两个集
值,以变化量识别出它们之间
niZable。状态Y是显示器的认可,但可以
被混淆的特殊显示A当新的设定
值是最小值,因此,状态X是也
提供和制作为了避免这种混淆闪烁。
因此,显示器可能只在状态Y进行
在这样的情况不会发生的情况。但是,
闪烁状态提供了容易吸引效果
注意一个部分,其中参数的值是
changed. 改变。但应注意的是,在的情况下所表现出的
参考图1中的符号。3B,如果显示的状态Y
根据同样的规则,在由(B)所示的情况及(c)
图。如图3A所示,从而在相同的显示状态X,则
在X国的特殊显示器的差异可能
公认的,但在这种情况下,状态X的也做了闪烁
如在其他情况下,因此所有指示灯不规则
用途larly在状态Y关闭
[0073]应当指出,在其中的实施例的
控制被旋转到对应于所述位置
召回的参数值显示在列
召回后的图。图3A和图 如图3B所示,但这样
转动不是必须的。当控制不旋转时,
2004年9月16日
控制的位置是从显示内容不同,
但是有一点问题都没有关于该参数的设定值和
显示其价值的。
[0074]接下来,当多个离散的一个值
值显示为组显示部分24,
照明元件被布置成对应于可能的
值,分别为。然后,在正常显示,只有
对应于a的值的照明元件的LED
参数被接通的?RST亮度,如图
FIG. 图。图4A中,从而进行显示。在这里,三种照明
所提供的元素被布置成对应于
一?RST,第二和第三组,分别从
上侧。此外,当一个推子没有组(值)
属于,所有的LED熄灭,如图。4B。
[0075]在特殊显示器的,如在图1的情况下。3A 3A
和图 如图3B所示,照明元件的作为同一发光二极管
在正常显示已打开的第二亮度
如由在图的参考符号(a)所示。4A。
[0076]这也类似于图1的情况下。图3A和图
3B的一个变化是由之间的X状态和Y的状态
在特殊显示B到执行在预定的时间
在两种状态闪烁显示。然而,由于不存在
大小关系之间此处该参数的值,
该发光元件的发光二极管对应于新集
值被接通的?RST亮度,并且该LED的
对应于旧的设定值照明元件接通
关于在状态Y的第二亮度然而,当
存在对应于旧的集合没有照明元件
值时,显示部分的所有LED都在关断
在状态Y在由所示的情况
图。3B. 3B。
[0077]此外,当一个参数,该参数是一个值
二进制值显示为组开/关显示器
部34,该发光元件导通时的αRST
亮度为ON和被关闭OFF,如图
FIG. 图。图5A和图 SE,在的情况下,从而进行显示
的正常显示。
[0078]在这样的显示部分,只有四种
在旧的设定值和新的设定值的组合
调用场景数据的图的时间。5A和
FIG. 图。5B,但显示控制的原理是相同的
那些示于图 图4A和图 4B。作为结果,显示
风格的特殊显示A和在特殊显示器B
每种情况下是指那些由参考符号(一)至(d)中所示的
FIG. 图。图5A和图5B. 5B。
[0079]请注意的是,也可采用适当
结合上述三个例子,使的显示
一个参数,可以采取一个值比其他的价值
上述值。
[0080]在这个数字调音台,它有可能是显示器
部由以在上述进行显示的
样式,使得当控制被操作来改变
值的参数,根据该电流值
该操作可以被显示,而当所存储的场景
数据被加载时,一个参数,它是该值的一部分
从值改变在装载和部分的时间
它们不会改变可以很容易地分辨。此外,对于
改变的部分,它是能够识别在该变化
间之前和装载后的参数值。
[0081]此外,LED指示灯部分不改变
该参数的值被接通在所述第二
Page 15 第15页
US 2004/0179695 A1
亮度是比?RST亮度降低,从而使
有可能使这部分相对不那么显眼
如果没有的信息量减少,
强调参与的价值变化。
[0082]应当注意的是,它不是那么优选
执行特殊显示器的加载后很长一段时间
场面数据,因此当控制被手动地
装载后操作时,显示器的显示样式
对应的控制部分应退还给
正常显示。
[0083]接下来,处理与上述
显示和变化之间的其风格将
described. 描述。FIG. 图。图6是?oWchart示出的处理,但
的αoWchart示出了处理的特征部分
与来自处理有关提取的实施例
到检测中的混频器,设置参数的操作的
eters,显示,等等。的说明和描述
处理这比其他部分省略。
[0084]在此混频器,预定完成后
初始化后上电时,CPU 111执行预
被存储在ROM 112中确定的控制方案
由此开始所示的αoWchart的处理
FIG. 图。6,首先,在步骤S1中,操作内容
基于从所述检测信号被检测到的控制
电路115,然后,当任何的手动操作
设置控制被检测到,该如何进入步骤S2。
[0085]在步骤S2中,判断是否显示
式在对应于操作显示部
设置控制是正常显示。在此混频器,本集
每个参数的值被存储在设置缓冲
在RAM 113,如图设置。8。更
SPECI?和Cally,除了当前设定值,该值是
当前设置参数的值,在显示风格
在显示部分显示的值和旧值集
这是用于专用显示器的性能也是
存储在对应于各参数。Therefore, 因此,
参照对应的参数的显示样式
在操作设置控制(参数是通过设置
在设置在加工时控制),则显示
式在对应于设置在显示部分
得到控制。
[0086]当在步骤S2判定的结果是不
正常显示时,如何前进到步骤S3,其中,所述
在显示部分的显示样式被改变到正常
display. 显示。这种处理可以通过改变要执行的
在设置相应参数的显示风格
缓冲正常显示。
[0087]在接下来的步骤S4中,对电流值
存储在设置缓冲区参数中雅被改变
舞在步骤S1中检测到的操作,然后
重?ected在信号处理中的DSP 116,和
显示屏上的显示部分按照被更新
的变化和指定显示样式后的值。
[0088]接下来的步骤S4中,如何进入步骤
S5在哪当场景选择开关被打开时,
在步骤S6中执行的场景数据的再调用处理,并
那么如何前进到步骤S7。如果开关没有打开
上时,如何直接进到步骤S7。
[0089]然后,当一个指令,停止混合器,即
关闭电源或重新启动搅拌机在步骤检测
2004年9月16日
S7中的处理是?成品,否则该如何回报
到步骤S1以由此重复处理。
[0090]应当指出的是,当判断结果
在步骤S2中是正常显示时,如何进入步骤
S4中,不执行步骤S3中的处理,并且当没有
在步骤检测到所述设定控制的手动操作
S1中,如何直接前进到步骤S5。
[0091]步骤S6所示的场景数据处理召回
图。图6是在图1的?oWchart的处理。7. 7。
[0092]在该处理中,?RST,在步骤S11和S12中,将
对应于该导通的场景选择场景数据
开关从场景存储器加载和存储的
VERI?阳离子缓冲液作为新的设定值,当前设置的
该参数的值是从设置缓冲加载和
存储在VERI?阳离子缓冲液作为旧设定值,如图
图。8,在该处理中的步骤S11中,CPU 111
作为一个加载器。
[0093]该VERI?阳离子这里的缓冲区是一个缓冲区成
每个参数的值被存储在相同的形式
在设置缓冲,并且被提供给重?抽搐的值
参数的不中,在DSP 116的信号处理
但只对在显示部的显示,以使
操作以验证现场数据的内容是
loaded. 加载。
[0094]在随后的步骤S13中,老的设定值和
新的设定值进行比较,相互为每
在VERI?阳离子缓冲参数,使得显示样式
的参数设置为特殊显示AOR特殊
按照匹配/不匹配的显示器B
values. 值。然后,在步骤S14中,参照和按照老
和新的价值观,并存储在显示样式
VERI?阳离子缓冲液,在每个显示部分显示的是
在所示的方法进行更新。图3A到图5B. 5B。In this 在这种
事件,在每个显示部分,旧的和新的一组值
对应于控制对应于该参数
显示部分显示。由于不是所有的设定值
的所显示的参数,显示样式仅需要
将用于至少要显示的参数来确定,
在步骤S13中。
[0095]接着,CPU 111的功能中的一个比较器
在步骤S13中上述的处理,并作为
在该处理中的步骤S13和S14显示控制器。
[0096]之后,当在预览键44处于ON状态
在随后的步骤S15中,如何进入到步骤S16中
其中CPU 111等待,直到预览键44是
关闭,并更新显示参照,并根据
旧的和新的设定值,并存储在显示样式
在步骤S17中设置缓冲器。换句话说,当
预览键44时,记者被公认为
的不重?阿拉斯的信号中加载的场景数据设置
处理被接受,从而使装载的场景数据是
只用于显示,并呼吁新闻界的发布,
显示将返回到负载之前,在没有哪家
变化是在设定值。在CPU 111用作
教师在这些类型的处理。
[0097]在另一方面,当预览键44是不
在ON状态在步骤S15中,如何进入到步骤S18中
在其中设置缓冲器的内容被改写
该VERI?阳离子缓冲液,如图中的内容。8, 8,
和设置缓冲区的新的内容被发送到
 楼主| daladana 发表于 2016-1-9 10:26:38
Page 16 第16页
美国2004/0179695铝
在DSP 116在步骤S19中被重新?ected的信号中
处理,从而结束处理。In this 在这种
事件,在VERI?阳离子缓冲新的设定值是
在设置缓冲当前设定值。换句话说,当
预览键44未按下,国家被认为是
重新设置?阿拉斯加载的场景数据的信号
处理被接受,从而使装载的场景数据是
重?ected在信号处理。注意,这是不particu
用途larly必要在这里更改显示,但显示
此后将根据内容进行
设置缓冲区。另外,如果在DSP 116 automati
和Cally指的是设置缓冲区的内容,并执行
基于所述内容的处理,在步骤S19的处理
是不必要的。
[0098]通过进行上述处理,它
可以执行已描述的显示
以上使用图 图3A到图 图5B根据
每个设置的控制和指令召回的操作
场景数据,并获得其中所描述的效果。
此外,操作者可以很容易地确认的内容
场景数据,在不影响信号的处理,通过
试映键44的操作。
[0099]的例子,其中的CPU 111和等待
记者在预览的过程中不执行其他操作
键44是描述在这里,并且也可采用使一个
安排这样的场景选择开关41至43
按下一个又一个同时预览键44是
被按压,以验证现场数据的内容。
此外,它也可采用作出安排,例如
当预览键44被释放之前,现场
选择开关,加载的场景数据的内容可以是
重?ected在信号处理。根据前
莫迪?阳离子,在提到的内容的可操作性
多个场面的数据得到了改善。根据后者
莫迪?阳离子,在重新操作性?阿拉斯的内容
在VERI?阳离子后的设定的场景数据被提高。
[0100]此外,对于返回的特殊条件
显示正常显示,其中的例子当
控制被手动操作时,显示器的显示样式
对应于控制部分被返回到
正常的显示进行了说明,但也可采用
到所有的显示部的显示样式返回到
在操作正常显示。除上述外,它是
可采用作出安排,使得显示样式
返回到正常的显示当一个预定的时间
所经过的场面数据的召回之后,或者当
用户按下某个特定的宏开关,例如,一个开关,用于
改变显示器的正常显示,召回后
场景数据。它也可采用与这些条件结合起来
系统蒸发散的显示样式返回正常显示当
它们中的任何一个是令人满意?版。在这种情况下,该内容
设置数据将被改变,在每个显示器上的显示
部分应在时间点进行更新当
条件是有用?LLED。
[0101]此外,各显示部的显示样式是
不限于那些用图说明。图3A到图 5B,但
任何显示样式是可以接受的,只要它是一种显示风格
其中,当场景数据被召回,部分a的值的
参数是不同的前后召回部分
其没有改变,可以区分的认可。
例如,在特殊显示B中描述用图。
图3A到图 如图5B所示,显示可以仅在状态下进行
2004年9月16日
X(或正常显示)。然而,更优选的是
使用显示样式,其中的价值的一部分
该改变时,前两个值,并且参数
后召回可被识别。作为这样的显示样式,它
优选采用的显示样式,使得值
参数之前,召回后是simulta
neously呈现在不同的显示风格。
[0102]此外,例如在其中LED
能够照亮了在两个级别的亮度作为
所述显示部的光源和在改变
亮度根据显示内容已经
这里描述的,但它也可采用使用,例如
红色LED和到位前述的绿色LED
LED的一个反面?guration,其中每个发光元件
构成显示部分可以被选择性地接通
在红色或绿色的,以便显示的颜色以代替改变
的亮度。另外,它也可采用使用一
LED照明能力只有一个级别的亮度
而改变的地方明亮的节奏或闪烁的周期
ness. 内斯。然而,CON?guration的亮度哪
照明都改成可以使显示器更易于查看与
在一个更简单的浓度?guration的照明元件。
[0103]此外,例如在本发明所
应用到数字混频器已经在上面进行了描述
实施方式,但本发明并不限于此,并且
适用于其他的音频信号处理设备,如
合成器等。
[0104]此外,该程序用于使元件
包括CPU 111实现上述功能
被存储在ROM 112等提前,并且在同一
可以通过提供程序还获得效果
记录在非易失性存储器中,如CD-ROM或
一?灵活光盘和使CPU 111的负载来执行
从存储到RAM 113的程序,或者通过
使得CPU 111下载执行从
包括一个记录介质上记录的外部设备的
程序在其上或外部设备中存储的程序
在存储器中,例如硬盘驱动器(HDD)。
[0105]如上所述,随着音频信号的亲
本发明中,当场景数据存储的cessing设备
在其中被加载时,显示部分的显示样式是
由不同的参数值的一部分
从该值改变在装载和部分的时间
它们不改变,这些部件能够容易地区别。
[0106]进一步地,根据本发明的方案,它是
能够使一台计算机控制音频信号的亲
cessing设备,从而实现上述字符
该音频信号处理装置的地球化学和获取
同样的效果。
What is claimed is: 什么是声称是:
1,一种音频信号处理装置,其处理
音频信号,并输出音频信号,包括:
用于设定该信号的参数值控制
processing; 加工;
一个显示器,用于显示该参数的一组值;
用于存储该参数的值的存储器;
加载器,用于加载存储在所述参数的值
所述存储器;
Page 17 第17页
US 2004/0179695 A1
一个比较器,用于比较,当所述装载器装载
该参数的值,该参数的值设置为
装载用的加载值的时间
参数;and 和
关于制作显示样式的显示控制器说
按照一个比较显示不同
导致在匹配/不匹配由上述比较。
2,一种音频信号处理装置,其处理
音频信号,并输出音频信号,包括:
用于设定该信号的参数值控制
processing; 加工;
一个显示器,用于显示该参数的一组值;
用于存储该参数的值的存储器;
加载器,用于加载存储在所述参数的值
所述存储器;and 和
制作,说时加载器加载一个显示控制器
该参数的值,同时,所述显示
送参数的加载值和一个值
在不同的设置在装载的时候该参数的
显示样式。
3,根据权利要求所述的音频信号处理装置
2,其中
所述显示器具有一个能够发光的一个光源
多个样式。
4,根据权利要求所述的音频信号处理装置
3,其中
所述光源是发光二极管。
5,根据权利要求所述的音频信号处理装置
4,其中
所述光源的照明亮度为每个不同的
的显示风格。
6,根据权利要求所述的音频信号处理装置
5,其中
所述显示器被做成呈现参数的值
设置在装载的时间比在较低的亮度
该参数的值加载。
7,根据权利要求所述的音频信号处理装置
4,其中
所述光源的照明颜色是为每一个不同的
的显示风格。
8,根据权利要求所述的音频信号处理装置
2,其中
所述显示器是一个显示器,用于显示连续的值。
9,根据权利要求所述的音频信号处理装置
8,其中
所述显示器是向目前的重叠部分和一个
不同部分之间设置的参数的值
装载和的加载值的时间
参数在不同的显示风格。
10,根据权利要求所述的音频信号处理装置
9,其中
所述显示器被做成呈现重叠的部分和
使用?RST显示样式和不同的第二部分
显示风格,是比?RST不那么显眼
显示风格。
2004年9月16日
11,根据权利要求所述的音频信号处理装置
10,其中
当该参数的加载值比大
设置在装载的时候该参数的值,
所述显示器被做成呈现重叠部分中
第二个显示风格和?RST的不同部分
显示风格。
12,根据权利要求所述的音频信号处理装置
10,其中
当该参数的加载值比小
设置在装载的时候该参数的值,
所述显示器被做成呈现重叠部分中
的αRST显示风格并在第二个不同的部分
显示风格。
13,根据权利要求所述的音频信号处理装置
1,还包括:
导师提供的指令不重新?ECT的
由上述装载机在装载的参数值
信号处理,
其中当指令已经由所述提供
讲师的价值的加载时间
参数,该参数的加载值不
重?ected在信号处理。
14,根据权利要求所述的音频信号处理装置
2,进一步包括:
导师提供的指令不重新?ECT的
由上述装载机在装载的参数值
信号处理,
其中当指令已经由所述提供
讲师的价值的加载时间
参数,该参数的加载值不
重?ected在信号处理。
15。包含程序指令的计算机程序
由计算机可执行程序和使所述计算机
执行:
处理音频信号,并输出的处理的
音频信号;
设定的信号的参数值的处理
按照控制运算处理;
使显示器呈现的一组值的处理
参数;
存储所述参数的值的处理;
加载存储在所述参数的值的处理
所述存储;
比较,当装载的价值的过程
参数表示参数集的加载,一个值
在装载带的加载值的时间
参数;and 和
在制作显示样式的过程所述显示
根据该比较结果不同
匹配/不匹配由上述比较。
16。包含程序指令的计算机程序
由计算机可执行程序和使所述计算机
执行:
处理音频信号,并输出的处理的
音频信号;
Page 18 第18页
US 2004/0179695 A1
2004年9月16日
9 9
设定的信号的参数值的处理
使得,当装载的价值的过程
按照控制运算处理;
参数表示载荷,同时显示
使显示器呈现的一组值的处理
目前加载的值,参数和值}
参数;
tlhe参数在不同的设定在负载的调
学年上课。
存储所述参数的值的处理;
加载存储在所述参数的值的处理
所述存储;and 和
