向阳花
发表于 2018-3-28 09:53:51
用于商业空间的扬声器系统不仅需要提供卓越音质,还必须能够与建筑及其内饰轻松融合,VXL 系列线阵扬声器系统能够高度满足这些要求。2 u$ U) M) d* v
Speaker systems for commercial spaces must not only deliver high sonic quality, but they must also blend effortlessly with the architecture and interior décor. VXL series line array speaker systems satisfy both of these requirements to a high degree.
5 O l6 s' \# Q! f- d5 ^
+ Y( }8 t/ b5 F8 y8 h, T, Q
' G0 ]7 Y0 d. k4 X7 m VXL 系列的超薄机身仅 54mm 宽,不仅能与任何内饰完美融合,音效水平也非常之高。全频范围的低频响应对于原音再现至关重要。- N# x4 p4 ~5 F0 X# r8 Y+ n
Slim cabinets that are only 54 millimeters wide blend beautifully with any interior while providing top-quality sound for speech, as well as full-range frequency response with extended lows that is so vital to satisfying music reproduction.# t9 Q9 }$ _6 \) K! w. k* {
( C* D& `5 Y* Z2 o
9 ] {3 V$ ^7 b
附有钕磁铁的高性能驱动器垂直排列,用于创建出色线源。这样的配置适用于企业会议室、演讲厅、购物中心以及其他需要在有限空间内发表清晰声音的任意场合。# }1 ?7 t/ ^* G2 e# f% L. n W4 P, v
High-performance drivers with neodymium magnets are arranged vertically to create a line source that achieves outstanding projection. This configuration is particularly advantageous in corporate conference rooms, lecture halls, shopping malls, and other applications where clear speech must be delivered in a limited space.
; X( Z# g% ^# g0 J VXL 系列包含六种不同尺寸、颜色的型号,拥有广泛的适用范围。并且,一系列可选硬件使它的安装变得灵活。
/ R7 D8 u- f; I* J: k8 ~, A' n The VXL series lineup includes six models of varying size and color, accommodating a wide range of applications. A range of optional hardware is available for flexible installation.
8 |: E$ q8 m) j$ y4 s3 a# T8 N; ]; Z" V
2 T( Q J) l2 R; p5 m* L 来自纤细机身的杰出声音& | Y: f4 [6 C" P) ]( L, d8 v
Outstanding Sound from Slim Cabinets
* u0 ]( Y# g t& K5 r VXL 中使用的 1.5 英寸全频驱动器经过精心设计,整个系列均采用了钕磁铁与优质材料来调谐,这使得仅 54mm 宽的机身拥有出色的全频响应。从平滑的高点到华丽的低点,VXL 精准的原声再现使其成为演讲和音乐的理想选择。
, x3 U, k$ n; ~1 D7 ^/ ? The 1.5” full-range drivers used in the VXL series have been painstakingly designed and tuned with neodymium magnets and top-quality materials throughout, resulting in excellent full-range response from cabinets that are only 54 millimeters wide. Accurate reproduction from smooth highs to opulent lows makes them ideal for speech as well as music.
+ v4 P& y6 B! Y7 n 适用于多种应用场合
3 w0 h8 a5 P; I Adaptable to a Diverse Range of Applications' r5 H; g3 n! ^5 g. C4 N
后面板开关可以将投射角度设置为 20°(向上 10° 和 向下 10°)或 40°(向上 10° 和向下 30°)。* 可根据需要,对声压级和覆盖范围进行进一步的调整。将不同数量驱动单元的型号相结合,可增加更多的应用可能,IP35 防水防尘等级使得 VXL 系列产品同样适合于户外。
- K/ n- a& X6 l' q A rear-panel switch allows vertical dispersion to be set to 20° (10° up and 10° down) or 40° (10° up and 30° down).* Sound pressure level and coverage can be further adjusted as required by combining models with different numbers of driver units, expanding the range of potential applications. An IP35 water and dust resistance rating makes the VXL series suitable for outdoor use too.
5 s3 c# u2 v, G' O* y0 d
: C1 ^5 o9 e: x: |. I1 ^
& m, l! g) J1 o# \- x @ * VXL1-8 投射角度固定在 40°(向上 10° 和向下 30°)。 b: h l7 a$ Y( K8 b5 h" H1 Q
* VXL1-8 vertical dispersion is fixed at 40° (10° up and 30° down).0 ~+ F7 L5 L+ r, P
灵活的安装选项
}/ a2 ?* x, p% k2 V C1 v' d r Flexible Installation Options9 y" T5 q4 V- A4 Q% I0 t r
0 r2 K2 n. Q! G6 N& l) L m: Q" n) c: [% R
