叶枫
发表于 2004-8-2 06:23:00
ANT SOCKET(antenna socket)天线插座
8 r: g/ f) |3 l. L# E; }$ VAF AMP(audio Frequency amplifier)音频放大器
9 Z2 H2 A; x+ T+ Z- h# QACK(automatIC color killer)自动消色器9 j0 h2 }/ `' S1 o2 J3 N
automatic flesh control自动肤色控制
. G E4 t: }0 Q/ w L# q5 x' `AFC BALANCE(automatic frequency control balance)自动频率控制平衡调节
: e( Q# s+ c/ m, Z' z, T/ A+ q5 k q9 ~AGC DELAY(automatic gain control delay)自动增益控制延迟调节
9 o" `1 R" w: ^* D4 [# S" W6 fAGC DET(automatic gain control detector)自动增益控制检波器/ q( x* ]+ p: z0 B
APC DET(automatic phase control detector)自动相位控制检波器(鉴相器) B# q' H0 F3 N! a5 o0 p' S
BAND SW(band switch)频段开关
5 r8 u) @- K: X0 b: j# Tbeam alignment束电流校正7 [" c; L8 n- w* i/ k* ?% f/ B1 N1 f
black stretch circuit黑电平延伸电路
5 l: f: ]& h) E(B)blue蓝色;蓝色的. T3 _. o( _ v6 M: [+ y6 ~
blue cut off蓝枪截止调节
5 a ^4 Q2 A" g/ w6 W) _ h$ T. ]9 Lblue stretch circuit蓝电平延伸电路
. K- B# T, L p7 q9 i4 x1 f& ~burst gate色同步选通电路
* G1 E5 n7 i* ^5 a% Wburst phase色同步信号相位! Z4 E2 ~0 c" b: K7 ?( m! F2 F
CW OSC(carrying wave oscillator)载波振荡器 ; S6 M7 `2 [* z$ S4 [/ n& A( ?
CRT(cathode ray tube)阴极射线管(显像管)' \3 |# s; ]8 }* f
ceramic fiLTEr陶瓷滤波器
) z3 M! Y! s, A" O4 }% _% f, gchannel selector频道选择器' }- S% P5 h2 @; ?' A
choke coil扼流圈: i( d( B! F# ?+ _
CHROMA AMP(chrominance amplifier) 色度放大器1 x; u4 A; U! Y( m( L% {2 y7 ]
chrominance burst AMP 色度、色同步信号放大 5 ]- l0 a% ^! h0 C- i8 ^8 K: T3 L
clamper钳位器
V: g) u1 Z2 V: K8 Tcolor killer消色器
6 ]* j9 l1 H( S6 b1 sCTI(color transient improvement)彩色瞬态改善; @( o4 e4 L( B$ n
convergence会聚
9 Y U. H s5 qCCC(continuous cathode correction)连续阴极校正! F; P; I4 F) B" L5 T) \; x
corner correction四角校正 9 \% R" x/ Z/ h+ a# p/ Y
current limiter 电流限制器' E3 }# e* i& Y; X. u6 c
damper 阻尼器
0 A3 G2 g4 J# i% Mdriver transformer 驱动变压器- ]! k2 V. A+ q& R* C
DDCF(dynamic digital comb filter) 动态数字梳状滤波器
+ @3 C" v3 v9 b! x4 SDLTI(dynamic luminance transient improvement) 动态亮度瞬态增强
; ?, d, A5 R& t5 T1 tDCTI(dynamic color transient improvement) 动态彩色瞬态增强% i2 T4 `( a4 p/ ]$ i
DSC(dynamic sharpness control) 动态景物层次控制- }; G4 E/ P( o5 N _$ G
DSVM(dynamic sCANning veLOCity modulation) 动态扫描速度调制7 k: h9 T$ L' w* O' H% N: W" V
E-W Correction(east-west cor- rection) 东西向校正9 T8 G3 y) J6 n. Y6 ^2 B
FBT(fly back transformer) 行输出变压器3 @+ m6 d! g% m. j3 \/ O0 T/ w
fly back blanking 消隐
1 q3 U& C$ u4 r& zgate 选通: |8 C: [" F/ j' U! }
gray 灰度* _# `* }3 Q Z# z! t2 ~
green cut off 绿枪截止调节
% a$ y; y, Z! {, ^* PHV(high voltage) 高压
, f2 s) U3 C- T0 k9 thorizontal 水平(行)扫描' S; S- D, Z( N7 p+ c
H.LIN(horizontal linearity)行线性 7 n9 J! w3 Y% t
H.OUT(horizontal output) 行输出 * c! b: K+ \5 [
IDENT AMP(identifier amplifier)识别放大器9 Q: _. I7 H% a, D
identifier killer detector 识别、消色检波器& s# n8 V3 q, K, w6 n
LPF(low-pass filter) 低通滤波器! i* {8 z9 H: O \: _7 u" @5 a* p
main board 主印刷电路板3 l- M* e$ N5 J" u) D
matrix circuit 矩阵电路0 _ e$ f- c H3 Z* I
moire 莫尔波纹(波动光栅)3 L) H( ~" i2 y$ k- q. B
overload protection 过载保护
; n& k6 n, w+ c& f& i6 H) G# }PAL switcher 逐行倒相开关, ] `( E. o* U9 s- c& F( h9 |# f
PINcushion distortion 枕形失真: }$ J* T" A5 Y% t/ o* B t: ?* X
PDP(plasma display panel) 等离子体显示器) z5 C. ?! c1 E7 s
PIP(picture in picture) 画中画- B" e+ ^7 h. X! ^/ O! [
positive thermistor 正温度系数热敏电阻- M2 @+ K7 n* {& B7 q" q
power drive 激励功率0 n) |0 p) Z! T/ S: e6 k
power rectifier 电源整流器
' Q/ V6 j% k2 Z& l: Z: l1 \! Jpower transformer 电源变压器
9 S. g; _' I1 G% framp generator 锯齿波发生器. v% a m) @3 h! C5 f+ |
(R)red 红色.红色的3 L( N2 Q+ e6 k
red cut off 红枪截止调节
( Z$ D% S# m! C) rregulator 稳压器' |1 h. q0 v3 t7 c5 n. c
SAW-tooth wave generator 锯齿波发生器
( @4 ?8 A9 B4 vSECAM(séquential couleur a mé- moire) 顺序传送彩色与存储
+ f0 y; b0 q/ s# Y q* c H3 ?/ S6 `4 DSAW(Surface acoustic wave) 声表面波滤波器
" Y- I- L, e7 ?$ w" Z! h! aUHF/VHF tuner 超高频/甚高频调谐器! E: o" h; B3 U
VM(velocity modulation)速度调制" ~9 h8 ?- f) s" T3 o9 S
vertical trigger 场触发
$ R# ~8 ?7 O3 Q& H5 pVHF(very high frequency) 甚高频 |
