FS飞扬专业线性音柱扬声器CT0508_音箱_音频应用论坛 - Powered by AUIOAPP
[全频箱] FS飞扬专业线性音柱扬声器CT0508
文子 发表于 2006-7-22 01:09:00
FS飞扬专业线性音柱扬声器CT0508( n* I6 k. ^; ]6 F& t) F
4 _0 k4 n  J7 Z% Q: i          经验告诉我们在承接会议展览中心、博物馆、单位多功能厅、教堂、机场、地铁站、火车站等场所的扩声上程时,音频工程师通常要解决的是由于声场环境的混响时间过长而引起的语言清晰度低下、音色混浊等听感不良的问题,所以在室内扩声中,获得均匀的、清晰的声音仍然是日前扬声器设计的发展难题,在高混响的空间扩声领域要求使用高Q值的设备:我们需要将直达声最大最直接地传达到聆听者的耳朵,与此同时需要减低由墙壁,天花板及其它对声音有反射表面所引起的反射声,所产生的残响极低,声音的清晰度可以获得很大的提升,使语言可懂度和音乐的感染力足够。FS专业线性音柱扬声器系统是人量运用了业界最新技术开发而成的新型建筑扩声产品,有效地解决了这个问题。2 S5 H! a5 N8 ]; G6 A' ?' b
; d% @# I; b7 @' B1 v9 |# u
参数:
- K' u7 `  L5 Y  nComponents    15" coax woofer
, P' u  |4 ~% @3 E/ ?% K$ UFrequency Response (Hz)    45-20k
( m9 ]& `) T$ s, K# vImpedance (OHM)   8
+ N+ z9 ?% n8 f4 I( l2 KRMS Power (W)    450
: r! Q$ a; s6 u1 G* _- wDispersion (@6dB)   90°Conical" p7 _6 x  N/ i2 T, _* J& }& g
Sensitivity(1w/lm)(dB): E6 b% r, `$ U- M9 Z) t7 {! i
Max SPL (dB)    97" J" d+ g: R8 f2 w1 z2 t& a, P
X一over (Hz)    126
$ c1 y& n% g; B; b9 m' j5 e+ GConnection      2000
: G" Y9 t% w4 T- {Product Size (cm)   Speakon
1 q5 s7 t. Z! a% ~1 FProduct Weight (kg)  43.6x44x63
0 W6 x! e, Y& y/ f% B4 QShipping Carton Size (cm)
; E4 V: c; f4 R$ z) b% q4 m* \3 Z7 sGross Weight (kg)
* `/ z" x/ c9 V9 w( i$ `Passive/Active            Passive
% u4 A% x, O! f' I9 W$ n2 |# F          Experience tells us that in the convention and exhibition centers,museums,multi-function hall, churches,airports,subway stations,railway
# E/ _; O6 |$ _8 Cstations and other sound places, audio engineers always have to solve the acoustic problems of unclear sound caused by long reverberation time and sound reflection from roof or walls. It is still a challenge to design a good indoor sound with even SPL level and clearence.It needs high Q value speakers to lead the sound directly to audience's ears and reduce reflection from environment.   The column speaker systems designed by FS AUDIO is the extensive use of such speakers in public places.
$ R! m+ {, q0 P* N2 [6 k          CT-508 is a column with eight pieces 5" mid and sixteen pieces 1”neo dome tweeters.CT-304 is a column with four pieces 3.5" mid and four pieces
8 O& @& A4 V( m! E5 S* L, L1 s6 t/ W1”neo dome tweeters.CT-1 OS is a 10" active subwoofer which has power output and can be stacked with CT-304 as a full range active system.The amplifier module inside is Class D with switch power supply.) N& p- J& I: b1 E- I/ G
2 @' Y; D, v3 U
$ t; O# h3 e9 g5 f
4 F: M1 i9 R6 W/ o# W8 w
