李书馨
发表于 2006-10-29 18:13:00
得胜多功能数字便 携扩音器DA- 121OG
* q0 @0 l: P" S# f8 e7 }! K7 U6 N% C5 j* ]1 Q2 w0 w: s+ ^
产品特性(Features)
" y! q* Y& B& m# z ·DA- 121OG是一款集麦克风、功放、音箱、充电器为一体的多功能数字便 携扩音器
/ g: Y: @& {5 v0 r ·DA-121OG扩音器科学的腔体结构以及优秀的双线圈喇叭单元,成就了其超凡的音质效果。音频输出功率l0w,最大愉出功率可达12W.音源覆盖范围可达200平方米以上。无论是细微的低语,还是极致音量,不论 是讲解,还是播放音乐,DA-121OG带给你的始终是清晰、圆润、洪亮 的听觉享受5 l6 C7 L4 T) s. W
·采用 Class D数字功放模块,将能耗降到最低,让扩音器的使用时间延 长,可连续使用20小时以上;MCU智能充电管理系统,充电迅捷,安 全可靠,只需4-6小时即能充电饱和
3 T! d4 S4 J( L ·灵活多变的佩戴方式,适应不同用户的个性需求- s4 [- _4 F! p( i1 W, }3 w
·应用创新的Remote Switch线控专利技术,麦克风可遥控扩音器电源系 统,降低电源损耗,延长电池使用时间(此功能需配合HM-820微型手持 麦克风使用)
9 Z4 ~* c" m7 ^$ n. j0 b7 V; t9 X0 O ·采用audio passive feedback多级分频式自动反馈调节技术,语音清晰、失真小,不易啸叫- l% g* x4 ?$ k) G) p5 o$ ~- D
·采用3.7V/2200MAH大容量锂离子电池供电,可循环充电使用,节能环保" m, `2 u& W- M' ]
·可选购HM-820微型手持麦克风和精美便携袋,为用户创造更方便的使用方式
: j! D) Q7 y0 N& D _ ·DA-1210G is a portable digital amplifier with microphone, power amplifier, speaker and charging functions% [) w2 {9 V; M) s/ q' `
·12W max. output power for large operating range upto 200 square meter or more
: [0 b, k" y7 ?+ C ·Class D digital amplification module for low consumption, 20hrs continuous playtime
* N6 q( H# j9 {; e ·Built-in MCU intelligent charging management system for secure and short battery recharging time (4-6hrs)
2 N+ a. U0 D- A3 Q% n8 j ·Multiple wearing choices for convenient use" N& T" r: d0 u& n5 X" E
·Remote swjtch control on the mini handheld microphone (HM-820) for reducing the power consumption and extending the battery playtime (this function is available when being used with HM-820)9 n& G! _6 u/ R" g1 e! S
·Audio passive feedback adjusting technology for nice sound, low distortion and effective feedback rejection2 p x0 R# p' s! L/ s4 |4 g p
·Powered by 3.7V12200mAh high capacity recharging lithium-ion battery7 V8 |+ u1 l( M- z4 v& \
·Optional purchasing accessory: HM-820 mini handheld microphone, portable bag
5 U& J. E) t5 D9 d: f: u6 y/ l7 B0 ]9 B+ _: I
适用场所(Application)
" x2 a. D E0 R* _7 j ·适用于导游、售货、教学、晨练、集会、宣传、参观等
9 T* J y' N8 y% W% n" \& g ·Tour guide, selling, teaching, outdoor PA+ J1 r2 n0 b3 X0 p8 [6 o" F
技术参数(Specification)
* a+ f( g4 V! L, a' \ ·频率响应(Frequency Response): 80Hz-12kHz
$ y# q' r' m' o! ~ ·输出功率(Output Power): 10W (PM PO: 12W)) k% Z& E. i! B
·扬声器阻抗(Output Impedance): 4 Ω
\/ _5 A8 t$ f" s$ ]2 Y ·工作电压(Operating Voltage): 3.7V! @6 Z: M# X- R
·电池规格(Battery Specification): 3.7V/2200mAht锂离子电池. c# c3 ^7 J+ _1 T" L# h% f
3.7V/2200mAh lithium-ion battery2 q; [' E; R9 G
·充电器(Power Adapter Specification):外接DC 5V/75OmAh电源充电器
: j; q0 t. \, w6 y/ O DC 5V/750mA
2 v u; _ K7 u+ m( f4 X2 A% I% W4 X3 W* Y( Q6 h- Z# c
" c/ |2 _! E; g% `* g |
