超级灵活的V-Mixer调音台和Digital Snake套装
The Roland M-300 V-Mixer and Snake Bundle gives you a new level of portable convenience. RSS designed the M-300 to be not only intuitive, but also well-equipped for any scenario. The M-300 itself is a potent 32-channel mixer with eight buses, 11 built-in multi-effects, channel and bus DSP, and built-in stereo recording and playback. A beautiful full-color TFT display gives you the ultimate in visual feedback while you're working. And with the exceptional convenience of the included S-1608 digital snake, you've got a truly powerful live sound solution with the Roland M-300 V-Mixer and Snake Bundle.
Roland M-300 V-Mixer and Snake Bundle at a Glance:
The M-300 - an incredibly powerful mixer for its size
S-1608 digital snake makes stage setup a breeze - and sounds amazing
Digital convenience means you can be ready for any event in any setting
The M-300's 16 smooth faders, rich channel-edit section, and full-on system/utility panel lets you mix and tweak sound with ease. Color-coded and logically organized buttons also enhance your workflow. Overall, the portable M-300 gives you all the tools you need to mix consistently and efficiently. Four microphone inputs and an additional four line inputs on the board are ready to meet small-scale sound needs. For larger events, just use a single REAC cable to connect the S-1608 digital snake.
First, don't worry about lugging that cumbersome analog snake with you anymore - those days are over. The S-1608 snake connects with a single digital cable, and provides 16 inputs and eight outputs. The microphone preamps sound fantastic, and 24-bit/96kHz digital resolution keeps your sound quality intact on its way through the rest of the system. Compared to your old analog system, you'll not only be able to set up much faster, the end result will far exceed your expectations.
Because this is a digital system, you'll enjoy all the benefits digital systems offer. Topping that list is the ability to change scenes instantly from event to event. Whether you're a busy house of worship with multiple events happening each week or a touring professional who wants the perfect layout to control each song, you need a digital console to manage all of your needs - instantly. Push a button to call up a scene, and you'll see the faders, effects, routing, and parameters return exactly where you had them. The M-300 can handle 300 different scenes, giving you plenty of room to grow. You can also conveniently load and save your setups via PC software.
Roland M-300 V-Mixer and Snake Bundle Features:
32-channel digital mixing console, with 16x8 digital snake included
Eight buses and four matrices offer a wide range of potential for larger venues
Four FX engines with 11 built-in multi-effects
PEQ and delay on all outputs
4-band PEQ and dynamics on all channels
24-bit AD/DA for high-quality sound
Remotely controllable from a PC
Record and playback from USB flash memory
Add a digital snake for high-quality audio transmission, distribution, splitting, and merging
Compatible with M-48 Personal Mixers and other REAC components for flexible system design
Rackmountable configuration
Support for Left-Center-Right (LCR) sound system configurations
S-1608 digital snake with 16 input x 8 output configuration
Remote controllable preamps using an S-4000R (not included) or free RCS software
REAC low-latency digital audio transmission system
技术参数
Type Digital
Channels 32
Inputs - Mic Preamps 4 x XLR (Console), 16 x XLR (Snake)
Inputs - Line 4 x 1/4" (CH 5-8), 4 x RCA (CH 9-12)
Outputs - Main 4 x XLR (CH 1-4), 4 x 1/4" (CH 5-8) (Console), 8 x XLR (Snake)
Outputs - Other 4 x XLR (CH 1-4), 4 x 1/4" (CH 5-8) Configurable
Outputs - Digital 1 x S/PDIF (Optical)
Headphones 1 x 1/4"
Send/Return I/O 4 x XLR (CH 1-4), 4 x 1/4" (CH 5-8) Configurable
Data I/O 2 x REAC (Cat5e), MIDI In/Out/Thru, 1 x RS-232C
Phantom Power 4 x Channels
EQ Bands 8-band Parametric (Channel), 31-band Graphic (Main)
Aux Sends 8 x Aux Sends
Busses/Groups 8 x Bus, 4 x Matrix
Faders 17 x 100mm (Motorized)
Effects Yes
Talkback Yes
Computer Connectivity 1 x USB, Ethernet
Rackmountable Yes
Height 7.68"
Depth 19.01"
Width 18.5"
Weight 21.6 lbs.
Manufacturer Part Number M300-BAS |
