1,全模组化设计,功能齐全。包括16CH无贱模组,CD模组,卡式座模组等。9 m8 W- W: X9 r2 _# H0 z' @4 m
2,具麦克风高低音、回音深度、次数、延时调节功能。
2 C& [+ O( }, _5 X y3,具主、从切换开关,方便多臺扩音机进行串联。
/ x7 {# ]- K6 R6 _4,内置高品质的数位回音电路及激动器,使歌唱/讲话声音更优美。9 J. J; r/ C2 {+ L- v3 B
5,内置优先啟动开关。啟动后所有麦克风具有讲话优先功能。
4 D5 V" I, R- q# V" m+ j6,麦克风设有歌唱、讲话开关,更适合使用场所要求。! B5 K A& @; Y' U) i
7,具智慧充电管理功能,能进行自动充电,自动跳脱以防止电池过度放电。
% E8 h9 x# P& L7 \4 h/ l& E7 i. h1 ?8,具可伸缩拉杆、提手、滑动轮及叁脚架固定点,方便移动和安装。
4 B+ {* z0 c. K( J/ Y/ q9,CD模组具防震,远端控制(可选)功能,带LED背景灯光的日歷显示。1 P( q6 s& ]- N. r/ P9 X- e
10,卡式座模组,全电子逻辑控制,可自动回带,带LCD液晶数码屏。APAA快速搜索功能,速度和输出音量可控制。记忆体录音放大电路。' T! k" v1 g. X8 W' `/ b. O" c
! _/ [8 _8 _6 ^9 x# {6 K1 M. r) ^
" Q0 V! J! h1 q: E$ r( i7 L+ s |$ u5 f
"Multi-module Portable Sound System, including 16 CH wireless module,CD module,and cassette module etc.Every one or two can be selected,
& P$ l9 Q. E4 p% n/ T7 m* S"Convenient package with luggage-style wheels,easy to take with." p/ p" _: @! ?
"AC/DC(battery) powered operation, better for outdoor using.
6 c9 ?5 c% l/ f$ t- V"Two UHF receivers with 16 channel frequency choice,convenient for manual adjusting. n, m% w) d, e e
"Build-in CD plqyer and Auto Reverse tape player,assisting multi music resources.3 ]8 R0 z; R! k/ A: M
"Voice Priority (speech override music)function,suitable for urgent broadcasting.: h2 Y5 W, r( D0 I5 w
"Audio link Master/ Slave circuit,allowing the inter-linking of several units.; s5 A- _: d% D6 C) A0 t1 l! t
*Two-way speaker systems.
2 b9 L. R R, _* o/ [/ [/ A"Two UHF wireless microphones plus two wired microphones.
, j2 T) R4 U5 O% `6 _; a. r' L"XLR Balance and 6.3 unbalance share the same MIC inputting plug., w6 ]! b0 p; {* C* b' E) P
"CD PLAYER; Anti-shock,remote control (option),LED backlight and calendar display, standard panel size,A->B repeat.
( w2 `, R# j7 ~# a7 y) g, E% ?"Tape Player:Front loading type,electronic full logic control,auto reverse,LCD counter with LED backlight,CUE/REVIEW function,APAA search function.Speed or line out level control, record amp with ALC.9 i# E8 O# e) l7 \
中国hifi音响网
